Reverse switch oil leak
Old May 10, 2007 | 03:57 AM
Brettus's Avatar
Boosted Kiwi
Having a bad leak out the back of the reverse gear detent switch (I'm presuming that is what it is .
Anyway - it seems to be coming out of a small tear in the black plastic cap atv the back of it .
Is there some kind of gunk I can smear over it to seal it up or am I going to have to get a new one ?
Old May 10, 2007 | 04:03 AM
i would pull the cap... clean the f out of it and then silicon is you friend... i would do it from the inside if you can..
a photo would be nice.. i might have the part...
Old May 10, 2007 | 04:11 AM
Brettus's Avatar
Boosted Kiwi
Hi swoope - yeah , I tried silicone but I think I need special oil resistant stuff . I have pulled it out & there is nothing I can do on the inside as it is a sealed unit .
Do you have a complete spare trans you can scavenge off ?
Old May 10, 2007 | 09:19 AM
yep,
send a photo to my gmail address.
Old May 10, 2007 | 10:14 AM
alnielsen's Avatar
The dealer found mine was leaking the last time I had the car in for service. It was replaced under warrenty.
Old May 18, 2010 | 04:58 PM
Brettus's Avatar
Boosted Kiwi
Just had my 2nd reverse switch start leaking - that is your old one Swoope .
Wonder if it is a common issue ?
Old May 20, 2010 | 02:50 AM
maybe,
it can happen faster if you have modified the exhaust in any way..
but the switch i sent you was off a 05 tranny with 6k miles on it..
so if you want to know about the placement / exhaust issue send me a note via email.. btw. dixion rules..
Old May 20, 2010 | 04:02 AM
Brettus's Avatar
Boosted Kiwi
Midpipe is stock (gutted cat) . I think it's to do with tracking the car - maybe .
What is the next race in the series - Indy 500 ?
Old May 20, 2010 | 04:11 AM
yea,
it has been ok this year, kinda.. indy.
we should chat via email this weekend.. going to be home for a change.. and focused on catching up..
lots of questions, and a few answers.
Old Jan 12, 2011 | 01:17 AM
rqbs's Avatar
hi.. i have issues with the reverse switch oil leak. swoope mentioned about the modified exhaust so here we go..
The Car:
04 - Rx-8 - 6 Speed Manual
BHR Coils
AutoExe Exhaust
No Cat (straight custom pipe)
9K Miles
The Problem:
Gear oil leaks from the reverse switch.
Solutions tried so far:
Rubber/silicon seal (lasted about 3 weeks)
Custom made leather gasket (lasted about 1 month)
Any suggestion(s) would be appreciated. Thanks.
Old Jan 12, 2011 | 01:20 AM
Brettus's Avatar
Boosted Kiwi
yep - get a new switch and shield it from the exhaust heat .
Old Jan 12, 2011 | 12:39 PM
rqbs's Avatar
Thanks Brettus. Any chance I can keep the current switch?
Old Jan 12, 2011 | 12:41 PM
Brettus's Avatar
Boosted Kiwi
Sure - if you don't mind it leaking
Old Jan 12, 2011 | 12:57 PM
rqbs's Avatar
Thanks again. You know any place where I can order the switch online in US or Canada?
Old Jan 12, 2011 | 01:08 PM
alnielsen's Avatar
http://www.mazmart.com/
http://onlinemazdaparts.com/partloca...?siteid=214264
Old Jan 12, 2011 | 01:12 PM
alnielsen's Avatar
The neutral switch is next to the cat. The reverse switch is on the other side of the car. I recently had to replace the neutral switch.
Old Jan 12, 2011 | 01:16 PM
Chris's Avatar
Turbo Member
im getting the same leak... same switch too.
I almost want to just through some rtv on it
Old Jan 12, 2011 | 01:34 PM
Jethro Tull's Avatar
Living In The Past
My switch started dripping with only 500 miles on the car.
The replacement, now nearly 4 years old, is still drip-free.
Old Jan 12, 2011 | 02:09 PM
Chris's Avatar
Turbo Member
it seems like it leaks from around where it bolts to the transmission
Old Jan 16, 2011 | 12:05 AM
rqbs's Avatar
(Rx-8 2004 6 speed manual)
The two switches (Neutral Safety Switch and Reverse/Back-up Switch) are they interchangeable?
Old Jan 16, 2011 | 12:19 AM
alnielsen's Avatar
No, they are not. They are different sizes where they screw into the trans.
Old Jan 23, 2011 | 10:55 PM
not sure,
but i think they are the same switch..
i sent the reverse sensor switch in my spare tranny down under.. !
used the other switch to fix the same problem. the answer is once it fails. the leak is permanent..
Old Jan 26, 2011 | 02:38 PM
ASH8's Avatar
Super Moderator
YEP, as a replacement part they are Both the Same....Y612-17-640B, this Neutral Switch is used also as the Reverse Switch.
Old Feb 24, 2011 | 10:29 PM
mkmike103's Avatar
Any recommendations for shielding the exhaust heat?
Curious bc I'm replacing my switch, and don't want to have to do this again in the future.
Old Feb 27, 2011 | 07:04 PM
wowo76's Avatar
I can say after struggling with my neutral safety switch this afternoon and realizing that I was shipped the wrong switch. The head of the snesor is the same size, but the threaded portion on the neutral switch has a larger diameter than the reverse switch.
