Rx-7 plugs
Old May 8, 2007 | 06:51 PM
BlueRenesis82's Avatar
Registered Tracker
Rx-7 plugs
Ok, I got a set of NGK FD plugs to replace my OEM plugs. I thought I read that you needed to put some sort of washer on them to make them the same length as the stockers?
Any help would be appreciated
Old May 8, 2007 | 07:42 PM
rotarygod's Avatar
On my RX-7 I actually remove the washers to get the electrodes a little bit closer to the engine. They don't hit the apex seals on 13B's. Not sure about the Renesis but I don't see why they would. Those washers are actually seals. I've never had any issues without them though.
Old May 11, 2007 | 09:17 AM
Registered Tracker
which FD plug is the trailing?
Old May 11, 2007 | 05:36 PM
supergoat's Avatar
I don't "smell good".
It will be marked with a "T" on the plug.
I used them in my 05 with good results. The 04 is running the ones it got during the recall.
WranglerFan
Aug 21, 2022 01:29 PM
WranglerFan
May 31, 2022 07:51 AM
tallestmexican
May 1, 2018 07:22 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
DVerdeyen
Sep 13, 2015 11:19 AM
