View Full Version : Transmission Fluid Flush
AdamTay
05-01-2007, 01:59 PM
Ok, read a few threads for DIYs on changing your transmission fluid etc. but I can't quite find out if the dealer is trying to con me or not....
'04 AT, in for a regular service.
Apparently the dealer notices the transmission fluid is 'a little dirty' and wants to flush the whole system. Apparently this is more than just topping up 2 or 3 quarts and involves replacing everything (something like 12 quarts?).
Anyway, they want $195, deal or no deal?
mikeb
05-01-2007, 02:10 PM
195 seems high
i think i paid 150 last week or something
nycgps
05-01-2007, 03:13 PM
I will say
No FUCKING DEAL
Come on. I mean ATFs are CHEAP!
AdamTay
05-01-2007, 03:31 PM
Just found $120 at another local dealer. That seems to be a little better.
mac11
05-01-2007, 03:38 PM
i would say to change/flush as recommnded in the owners/maintinance manual
TeamRX8
anyone knowledgable in the trans business will tell you those flush machines are all overpriced marketing hype, just get a standard drop the pan and refill flush at an old school trans shop
AdamTay
05-01-2007, 04:02 PM
Current quotes stand at $99 for drain/refill or $120 for full flush. Worth the extra? Perhaps just going to some 'old school trans shop' would save me a bunch on the drain/refill?
Don't have the owners manual to hand the moment, but I'll give it a read later...
Thanks all.
nycgps
05-01-2007, 04:06 PM
Do it yourself.
Its Fun. and cheaper.
AdamTay
05-01-2007, 04:10 PM
I'm a little new to all this stuff, but when people talk about doing it themselves, they seem to be replacing 2-3 quarts, but the dealer seemed to suggest there was much more to be replaced throughout the whole system? And that they use some 'flushing machine' to clean it all out a little more thoroughly?
a DIY does sound like more fun though.
mac11
yea...the ATF to fill the trans yourself would prolly cost <$20
devildog1679
05-01-2007, 05:19 PM
Book says 1.85 quarts. I used almost 2.
AdamTay
05-01-2007, 05:27 PM
I think that for a manual, the owners manual seems to suggest 9.2 quarts of automatic transmission fluid.
Is the replacement procedue the same?
CosmosMpower
05-01-2007, 06:20 PM
Do it yourself, I did my manual tranny for 20 bucks.
mysql101
05-01-2007, 06:39 PM
thats about right for the MT, but they're talking about AT.
mac11
05-01-2007, 08:04 PM
i believe for an auto you are going to drop the trans fluid pan drain and clean it and then reinstall. At least thats how it was on a few of the cars I used to work on. That way you will be able to clean all the shavings off the magnet in the pan and be sure you have a (nearly) debris free tranny.
TeamRX8
05-01-2007, 08:17 PM
I'm going to give you this:
http://www.rx8club.com/showthread.php?t=74759
in exchange for you learning how to use this:
http://www.rx8club.com/search.php?
AdamTay
05-01-2007, 08:49 PM
tried all combinations of 'automatic', 'transmission', 'flush' and 'fluid' in the search, but only found the MT version.
cheers.
devildog1679
05-01-2007, 11:29 PM
OOPS, I need to get glasses.
ninjarama
05-02-2007, 12:58 AM
letting loose 9.2 quarts of transmission fluid? better get one of those gigantic sized oil containers lest you get tranny fluid spilling all over the place... won't be fun to clean up!
Old Rotor
05-02-2007, 01:41 AM
Did you see this "TSB" about the changing and flushing of the A/T. Look down the page til you find this one.....
AUTOMATIC TRANSMISSION COOLER/LINES FLUSHING PROCEDURE
http://www.finishlineperformance.com/rx8/bulletins_index.html
AdamTay
05-02-2007, 03:26 PM
Interesting thanks. It does seem to suggest there is significant advantage to flushing over a simple drain and refill, which doesn't seem to be everyone's opinion.
ninjarama
05-03-2007, 07:15 AM
That does not look like fun! I liked chaning the fluids on my MT better... I wouldn't say that's fun either, but much simpler to say the least! Support the car on 4 jack stands, unbolt trans. -- drain, rebolt & refill...unbolt rear diff. -- drain, rebolt & refill. The only thing that would mak it easier is if you could fill from the top like engine oil =)
