NW RX-8 Forum Serving WA, OR, ID, AK
it wont go up!!
Old Apr 30, 2007 | 06:12 PM
psu15582's Avatar
it wont go up!!
on my way back from work today, i was going up a steep hill when suddently the car lost power and started to slow down and finally engine shutdown. I turned the ignition on again and tried to go, but it just wont go up the hill, made a U turn and went to the dealer. on the way there I can feel the car heavier than it used to be. I need to step on gas more to get power. so i left it there and they gave me a cx7 loaner. as some of u remember i have the 04, automatic. any ideas here?
Old May 1, 2007 | 09:52 AM
BunnyGirl's Avatar
Did you ever have the recall done? Sounds like a problem that prompted them to do that massive recall and testing. Which dealership did you take it to?
Old May 1, 2007 | 09:53 AM
eviltwinkie's Avatar
Sounds like you should slip it some viagra...
Old May 1, 2007 | 02:59 PM
psu15582's Avatar
i used royal moore, and they did the recall too last year. well i'm still waiting to hear from them!! will see
Old May 4, 2007 | 11:35 AM
psu15582's Avatar
replace the engine
OK, they just called me today and they are going to replace the whole engine. wow, how about that???????
Old May 7, 2007 | 01:56 PM
kristopher_d's Avatar
Drive Master
Now that you've learned your lesson, you'll rev the hell out of her on a daily basis, right.
A redline a day keeps the carbon away.
Old May 13, 2007 | 02:14 PM
shaunv74's Avatar
Power!!
I think Mazda needs to put in their owners manual that they recommend hitting redline at least once per trip once the engine is warmed up. How cool would that be...The manufacturer says REV IT UP!
Old May 14, 2007 | 09:33 PM
psu15582's Avatar
actually I do rev the hell out of it whenever I can, but the dealer said the engine has failed the vacume test, the same one that I passed on the last engine recall that I did few months ago.
now let me ask you here will replacing the engine make the car depreciate more, less or it wont affect?
Old May 14, 2007 | 09:39 PM
Easy_E1's Avatar
Should not depreciate it as it has a new engine. So who ever buy's it will get more miles out of it. Look at it like you were buying it. Would you want a new engine or one with 40,000 miles on it?
Old May 15, 2007 | 02:18 PM
shaunv74's Avatar
Power!!
When they replace it make sure they visually check the catalytic converter and replace the ignition coils. DMP had his engine replaced but still had problems because the asshat dealer wouldn't replace the ignition coils an clogged Cat. which were the cause of the problem to begin with...
Old May 15, 2007 | 05:21 PM
Nemesis8's Avatar
Bigus Rotus
The auto should have had water cooled oil coolers IMO with big fans.
