Airbag problem
Old Apr 29, 2007 | 08:56 PM
c0ldf1ame's Avatar
Airbag problem
hello
so i switched my 06 black/black interior for an 04 black/chaprall interior, so during the tear down i found many differences
but anyways i had to take off the steering wheel, which required taking out the airbags, after i put them back on, they airbag signal light turns on, blinks a couple of times, goes off and comes back on again. Also my passenger side airbag light stays on now indicating that the airbag is turned off. I havent checked all connections yet, and i have to take off the steering wheel again anyways to reinstall it properly centered (its off by a little right now), so i will check that out, but initially
does anyone have an idea?
also my traction light comes on now after a few minutes of driving and wont turn off, though it doesnt feel any different and i cant switch dcs off.
Old Apr 29, 2007 | 09:09 PM
tiggerlee's Avatar
May Cause Anal Leakage
Did you try resetting it since you disconnected the battery?
Old Apr 29, 2007 | 09:14 PM
c0ldf1ame's Avatar
how do you reset it?
Old Apr 29, 2007 | 09:22 PM
tiggerlee's Avatar
I believe it is...
1) Turn the key to on
2) Depress the brake pedal rapidly 20 times in a row until the oil pressure gauge sweeps to halfway and back again.
It's been awhile since I tinkered with an 8. but I'm pretty sure that's it.
Old Apr 29, 2007 | 11:17 PM
turn the wheel all the way to the right then all the way to the left the all the way back to the right..
that will clear the dsc.
Old Apr 29, 2007 | 11:47 PM
c0ldf1ame's Avatar
the dsc is cleared, but no traction light still comes on
Old Apr 29, 2007 | 11:49 PM
do you have an owners manual?
Old Apr 29, 2007 | 11:51 PM
never mind.
check pm.
Old Apr 30, 2007 | 12:47 PM
c0ldf1ame's Avatar
i reset the pcm using the key to on and 20 brake stomps but the traction light still showed up,
gonna take it apart this weekend probably and check everything, if not dealer time, if dealer charges up the ***, then aftermarket seats and steering wheel here i come!
swoope, pm replied
theblinkof
Oct 4, 2023 05:24 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
