RP SuperCat CEL, help!
Old Apr 26, 2007 | 08:29 PM
spd frk's Avatar
Conflicted
I just installed my RP supercat. I put a new O2 sensor in at the same time. After 60km of driving the CEL is now on all the time. It flashes when I am at full throttle, then will return to solidly on afterwards.
Is this a problem, or is the CEL supposed to be on??? Even with a header and highflow cat my old car never had a CEL.
Should I cought up and have Mazda read the code that goes with it?
yes I searched too, but couldn't find anything specific.
Thanks,
Juergen
Old Apr 26, 2007 | 09:23 PM
Flashing CEL means something else.
Turn it back to stock and see what happens. Thats what I would do.
Old Apr 26, 2007 | 10:09 PM
Do a search.. I think you need a specific O2 sensor, otherwise other brands do not work.
Old Apr 26, 2007 | 10:36 PM
chickenwafer's Avatar
Nope
you need the code to know what is is for sure. But right now I would be guessing thatnew O2 sensor
Old Apr 26, 2007 | 10:39 PM
Labop's Avatar
TAke it to autozone/pep boys/partsplus/whatever. Most name brand parts places will read the code for free.
Old May 1, 2007 | 04:02 PM
kwescott's Avatar
One ball, corner pocket
aamco will read the code for free as well.
Old May 1, 2007 | 04:03 PM
kwescott's Avatar
I have the RP supercat and have had no CELs. Actually, I've never had a CEL with the car. Other option is to post a thread in your regional forum, to see if anyone local to you has a the scanalyzer tool...
Old May 1, 2007 | 04:06 PM
maxxdamigz's Avatar
Baro Rex
I get codes read at Autozone all the time.
Old May 1, 2007 | 05:54 PM
staticlag's Avatar
The Professor
reset your computer by disconnecting the negative battery cable and letting it sit overnight if your havent done so already
Old May 15, 2007 | 09:37 AM
Chris_R's Avatar
spd frk, just wondering if you got any resolution on this. I installed the RP SuperCat and after less than 300 miles I have a CEL on all the time. Before that no CEL's. I don't want to clear the code until I know what caused it. (By the way, I used the stock 02 sensor).
Old May 15, 2007 | 09:54 AM
Moostafa29's Avatar
Storm Trooper
Did you replace the gasket or use the old one?
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
