416to212
04-26-2007, 11:18 AM
I'm not lowered and don't plan on being lowered so I'm wondering if it would still be safe to run the following:
19x8.5 F
19x9.5 R
+25 offset
Am I just NuTz?! What tires should I go with?
I've bee searching the threads for a long time and I have yet to see this type of combo. Just wanted to know if it would work.
What I'd really like is a Sticky Thread with all the possible wheel and tire combos. If any one could direct me to such a thread I'd appreciate it.
ChrisRX8PR
04-26-2007, 11:35 AM
19x8.5 F
19x9.5 R
+25 offset
I think 35mm is as small an offset as you can go on 8.5front and 9.5rear and even then you'd need a 255 tire in the rear in order to not have to roll your fender. You can use up to a 275 if you roll your fender. Anything under 35mm with a 9.5 width will make your rim stick out from the car and it wouldnt look good. mine is exact with the side of the car and its a 35mm you would be 1 full cm sticking out past the fender....not pretty. You could use a 8.5 rear with 25mm offset and it would be ok. Hope this helps...
Chris...Esmeril
416to212
04-26-2007, 11:54 AM
Chris thanks for the tech.
So what are you running right now with the tire specs too please. I'd like to be flush and sitting pretty too.
RA-Eight
04-26-2007, 12:21 PM
You can go even more aggressive than 35mm in the front on 245/35 and be okay. I'm running +34mm, with add'l room. Some members are in the upper 20s with no issues. I'm not sure about +25 though. You will definitely have issues in the rears with +25 without fender mods.
ChrisRX8PR
04-26-2007, 05:08 PM
I am running 8.5" front with 225-45 and 9.5" rear with 275-35 and I it would rub at the rear when taking dips on the highway. I rolled the fenders and it works perfect. It wouldnt rub with a 255-40 on the same 9.5" rim though and look just as good.
ChrisRX8PR
04-26-2007, 05:14 PM
What you say is very true but you cant just speak of offset and tire size. It has a lot to do with the rim width as well because the same size tire will stick out more on a wider rim. If the front rims are 7.5 or 8" wide then you could get away with a mid 20 offset but if the wheel is 8.5-9" then you cant without having it stick out. I 35mm on 8.5 rims and I can tell that its already at the maximum width it could be at(otherwise it would look like a bigfoot with the tires stiking out the side) unless you go with agressive camber or something like that which isnt too street friendly.
RA-Eight
04-26-2007, 08:55 PM
We're talking 8.5 width front and 9.5 width rear. I can't speak for your fitment, but I'm running 19x8.5" wide front on 245/35, lowered on Tein S-Tech, and I know I can run a few more mm out and be perfectly fine and still be flush to the wheel well.
Check out the Rays Wheels thread, and you'll find a variety off more aggressive offset with no issues and are flush to the wheel well.
auzoom
04-28-2007, 08:44 AM
In comparison to the OEM rims (18" x 8" +50) and tyres (225/40/18) a 19" x 8.5" +25 will have 19mm nore clearance on the inside of the wheel and will stick out 31mm closer to the lip.
A 19 x 9.5" + 25 rim (in comparison to OEM again) will have 6mm more inner clearance and will stick out 44mm closer to the lip.
Looking at places like http://www.1010tires.com/WheelOffsetCalculator.asp help get an idea of it works, but remember that when keeping the same size rim width, a smaller positive offset means less room between the rim and the lip.
More_Revs
04-28-2007, 11:12 AM
Look here (http://rx8club.com/showthread.php?t=115148)
