blow off outside the engine compartment??
Old Apr 24, 2007 | 12:24 PM
ARC.4.LYFE's Avatar
i have a greddy turbo kit with the greddy blow off valve and i want the blow off to be outside the car (like in the wheel well). does anybody know how i would go about doing that. one guy told me to use pvc pipe but i think that might look ****.
Old Apr 24, 2007 | 12:32 PM
maxxdamigz's Avatar
Baro Rex
You need to mount a piping system from the BoV flange to your desired location, put a flange and some support on that pipe, and mount your BoV with any connections there. Then, you will continually need to police the valve to make sure it is not damaged by debris coming off your wheel. It will increase the pressurized volume of your intake and decrease BoV performance. It would be expensive to get done at a shop, require cutting holes in at least your wheel liner, and just, in general, sounds like a bad idea. If you did it in PVC, you could crown yourself king of the ricers though and put V-Tec stickers on your car.
If you just want the BoV to be louder, you can buy a louder BoV and put on a vented hood, turning the BoV so that it faces the vent.
vapor2
Nov 3, 2020 03:38 PM
uZu
Dec 30, 2015 12:35 PM
Solmors
Aug 21, 2015 10:11 PM
CA441914
Aug 5, 2015 11:33 AM
marc2820
Jul 26, 2015 10:47 PM
