25k miles later, took off the sunroof wind-guard... black marks!
Old Apr 22, 2007 | 10:22 AM
Imidazole's Avatar
So I figured I'd take off the sunroof wind-guard that came on factory, and now on the roof there is a black outline... the black rubber left what seem to be perminant marks in the paint!
Anyone else have this happen, and know a good fix?
Old Apr 22, 2007 | 10:25 AM
Nopstnz's Avatar
If it came that way from the factory take it back to the dealer and point it out to them.
Old Apr 22, 2007 | 10:36 AM
Imidazole's Avatar
Is that a valid warranty claim?
25k miles, I took off the wind guard, and it left behind permanent black marks.
Old Apr 22, 2007 | 12:42 PM
maxxdamigz's Avatar
Baro Rex
Hmmm. If it's rubber that has rubbed off onto the paint, that can likely be removed. If the rubber has worn the paint, at would need to be repaired. If your paint has any hint of fade, the wind guard probably left a fade/shadow. I have a black car with a wind guard and the only time I'll probably ever take it off is to clean under it and then put it back on.
Old Apr 23, 2007 | 11:36 PM
Astral's Avatar
Purveyor of fine bass
I bet you're SOL. However, try claying the area (a lot of it is rubber & dirt bonded to the paint). When I had to do it on a silver car, it helped a bunch. If that doesn't help enough, try hitting it up with some Meguiar's ScratchX.
Old Apr 24, 2007 | 08:06 AM
Astral's Avatar
why would it be warrantied? it's a stock accessory rubbing against paint, causing paint to come off. paint didn't just come off by itself.
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
mariohardleft
Feb 6, 2016 12:59 PM
HMSS013
Aug 28, 2015 03:08 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
