Smell of gaz??
Old Apr 22, 2007 | 07:36 AM
rx8frank's Avatar
White RX8 R3
Smell of gaz??
Before you say it I did SEARCH.....
Ok here it goes...I left my car idle for about 3 min. and when I came back to it; it smell gazoline like if it was spilling on the ground, so I moved the car to see and guess what NOTHING . Can you please tell me if someone had that issue and how to resolve it
Old Apr 22, 2007 | 01:11 PM
Go48's Avatar
The rotary engine runs a very rich fuel-air mixture at start up, so my guess is that is what you are smelling from the exhaust. Other than that, if you still smell the fumes after the car is fully warmed up, take a flashlight and look around the engine for a leak.
Old Apr 22, 2007 | 04:46 PM
dillsrotary's Avatar
jersey fresh
have the dealer (or yourself) check for an injector leak ASAP.
Old Apr 22, 2007 | 05:33 PM
tajabaho1's Avatar
Destroying Threads
dude, go check leak, if it leaking, you could end up.............well done?
Old Apr 22, 2007 | 05:48 PM
_Logan_'s Avatar
Got the latest flash?
Mine always smelt bad on startup, it got better after I got a new flash and after I had started really revving the engine
Old Apr 22, 2007 | 05:56 PM
rotten42's Avatar
Mentalhealth is overrated
BINGO!!!!
That's what happened to my car.
Old Apr 23, 2007 | 06:43 AM
rx8frank's Avatar
White RX8 R3
I'll do that...thank you all for your answer
Old Apr 25, 2007 | 08:14 AM
rx8frank's Avatar
White RX8 R3
And by the way can someone tell me where I should look in the engine bay for the injector and where the leak should be...
Old Apr 25, 2007 | 08:23 AM
Nemesis8's Avatar
Bigus Rotus
I would not even drive the car, have it flat bed towed directly to the dealer.
Ovr-9000
Apr 7, 2016 11:19 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
Rx8_412
Sep 24, 2015 08:51 PM
chadsta
Sep 20, 2015 11:00 PM
