Engine Check light
Old Apr 18, 2007 | 02:24 AM
theboy's Avatar
RX8 newbie!
Engine Check light
I did a search and had follow this problem for quite a time now.
a member from north borneo have problem with the car CEL,
we went through checking the ignition coil, spark cable, spark plugs, O2 sensor and found no problem. what is the next suggestion?
the car seems to be working fine, it is still running normal, its a 6 speed manual. just that the light is on.
Old Apr 18, 2007 | 10:07 AM
What CEL is it ?
Old Apr 18, 2007 | 10:50 AM
StealthTL's Avatar
Metatron
Cool Reader....
You need a code reader, one that can read the new "CAN"bus standard.
Read the number, and use the sticky (in the Tech section) of the codes to pin down the problem.
S
Old Apr 18, 2007 | 07:23 PM
theboy's Avatar
RX8 newbie!
we tried all the CAN diagnosis machine here, they are all not up to date. they are only up to RX7.
any other possibility?
Old Apr 19, 2007 | 05:38 AM
Go48's Avatar
Then they are NOT OBDII, CANbus-compatible scanners. Do a search on the forum for sCANalyser to read about it. This is a system that was developed by a couple of forum members in Australia and it has had good reviews. You can purchase it on line. It requires a computer, BTW.
Edit: Go here for purchase information:
http://www.performancedesign.com.au/
Old Apr 19, 2007 | 10:43 PM
RX7 ? rofl
Just like what Go48 said, get an OBDII CAN-bus compatible scanner. you should be able to get one cheap at your local auto parts store, most new cars has that port so theres NO WAY that you cannot get such scanner.
Old Apr 22, 2007 | 10:41 PM
kdparsons80's Avatar
I have a similiar problem my light came on at 115mph any ideas?
Old Apr 22, 2007 | 10:43 PM
toxin440's Avatar
You went 115? you just voided your warrenty man. Anytime you go over 109mph the CEL comes on and stores a code in the RX8's PCM. Next time you go in for service they can pull this code and know you have been over the set limit.
haha just ******* with you - most likely you had a misfire. i was doing a very high rate of speed one time on the highway and had the same thing. I bought Harrison CanScan tool and cleared it.
Old Apr 22, 2007 | 10:46 PM
Cody Red's Avatar
always filling [the c]up
check your MAF sensor. if not, you need to get it scanned. I remember reading a post that had ALL the codes and what they meant. Wish I would have subscribed to it.
-Cody
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
MarkX
Jul 31, 2015 07:50 AM
marc2820
Jul 26, 2015 10:47 PM
