Radiator fan stopped working....
Old Apr 10, 2007 | 01:45 PM
Jeromie's Avatar
i really dont know when this started but i remember that it would turn on when the car was parked and off, now even when i drive it hard and i just park it, nothing happens??? wondering if the newest dealer flash makes it turn on differently or wat?
Old Apr 12, 2007 | 12:08 AM
Jeromie's Avatar
just to add to my problems ive been noticing.... i noticed my old cat would glow red so i figured bad cat right? well i replaced it with a high flow and now this one does it too. the mods i have are custom intake and exhaust. dunno if that would really do anything........
Old Apr 12, 2007 | 02:29 AM
Mazdaspeed RX8 ver2's Avatar
does your 8 overheat? if it does, then maybe you may just have to take it in. I have no clue on the glowing cat though
Old Apr 12, 2007 | 06:47 AM
mysql101's Avatar
the fans turn on based on coolant temp. if it's not hot enough, it doesn't activate.
Old Apr 15, 2007 | 10:33 PM
Jeromie's Avatar
well i drive it like cheap ***** so i think it should get hot enough.
but yea could the fact that i may have low coolant have to do with it not getting hot???
Old Apr 16, 2007 | 03:17 PM
Nubo's Avatar
Lubricious
Without looking to see where the sensor is, it's possible that low coolant could mean the sensor that triggers the fan is not in contact with coolant.
Personally, I have to drive hard AND in hot temps (>90F) before I notice the fan running after shutdown. Since I got the car in a February, I'd been driving it for some time before it first happened. Shockingly loud the first time you hear it! And you think "omg there goes my battery"
Old Apr 16, 2007 | 03:57 PM
Jeromie's Avatar
today i will make sure my coolant is full. it could just be like u say since its not really hot out latley...
Old Apr 18, 2007 | 01:09 AM
make sure nothing is stuck in the fans themselves.. a couple of people have had rubber bits stop the fans from working.
Old Apr 18, 2007 | 11:56 AM
Jeromie's Avatar
could someone plz explain where it is??? i can see my radiator eaisly from the front. the back looks perty hard to get to.....
Old Apr 18, 2007 | 12:36 PM
StealthTL's Avatar
Metatron
Cool Not ....
The thing you see from the front is actually the a/c condensor.
You can check whether the fans are working by pulling out the two relays, one at a time, and jumpering the two big contacts - the fans should spin (you can hear it, you don't need to see it).
If they are working, you just have to trust that the ECU will use 'em when it needs'em.
S
Old Apr 18, 2007 | 12:57 PM
WOWSaLifetaker's Avatar
I've had to do this to my buddy's rx7 his relays went bad and he over heated =( but luckly turned it off immediately. It was the high speed relay that went out so when the car was high temp it wouldn't turn on.
Old Apr 18, 2007 | 08:48 PM
Jeromie's Avatar
Originally Posted by StealthTL
You can check whether the fans are working by pulling out the two relays, one at a time....
S
so.... which relays do i pull? fan1 and fan2??? or are those fuses im thinking of.
plz go on and explin more for me how this is done...
Old Apr 19, 2007 | 10:10 AM
mazdatech177's Avatar
honestly, if you dont think its overheating i wouldnt worry about the fans. but if you want to see if they work just turn your a/c on, the fans will come on with the a/c command. this checks the fan motors, wiring and relays... but not the coolant temp sensor. turn a/c off and set parking brake. hold engine rpms at about 3k for 3-4 minutes... thats my engine over-heat/thermostat/cooling fan test. works well for me
of course adjust your coolant to proper level
Old Apr 20, 2007 | 11:38 AM
Jeromie's Avatar
filled the coolant the other day. i will do ur test today thanx!
Old Jun 14, 2007 | 10:38 PM
Deuse's Avatar
any word?
Old Jun 15, 2007 | 01:35 AM
in order to *see/have access* to the fans, you have to take the stock intake (if its there, but guess not)
to have Full access, u have to take the battery box out as well.
Its easy, 15 minutes the most.
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
olyrx7
Oct 26, 2015 09:23 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
