Series I Do It Yourself Forum Wanna save some coin or time/money in the shop? Read up on Do-It-Yourself custom mods and repairs & post your own here.
DIY: Rear shock/coilover install
Old Apr 8, 2007 | 07:07 PM
PUR NRG's Avatar
Just put in a new set of coilovers. http://www.hi-impact.org/ryang/modif...hock_rear.html has the full write-up. You can see all my other DIYs at http://www.hi-impact.org/ryang/modify/modify.html. PM me with any additional questions, feedback or suggestions you might have to make these DIYs better.
________
Lamborghini revent?n specifications
Old Apr 8, 2007 | 08:28 PM
d j's Avatar
d j
hukbong himpapawid
outstanding! Thanks for sharing!
Old Apr 8, 2007 | 08:50 PM
Astral's Avatar
Purveyor of fine bass
fantastic detail and pictures! great job!
Old Apr 8, 2007 | 10:29 PM
Im_DANomite's Avatar
I love GOOOLD
one suggestion...you don't have to remove the sway bar endlinks in the rear.
1. mark the alignment eccentric bolt with a marker so that you can install it back to where it was...closely.
2. loosen the 19mm nut and tap out the bolt and washer for both sides.
3. swing down both controls arms and let it hang. no need to disconnect the endlinks.
not that big of a deal, but it's just one more thing you don't have to do and make the install a tad quicker. great write up tho.
also, no need to unbolt the front sway bar as well.
Old Apr 9, 2007 | 11:18 AM
PUR NRG's Avatar
Originally Posted by Im_DANomite
one suggestion...you don't have to remove the sway bar endlinks in the rear. not that big of a deal, but it's just one more thing you don't have to do and make the install a tad quicker.
My experience was the shock would hang up on the sway bar if it wasn't rotated out of the way. But I don't recall if that was before or after I tried tilting the shock bottom directly away in order to remove it.
When you disconnect the upper control arm, the sway bar will keep the wheel hub oriented vertically and make it harder to remove the shock assembly. Disconnecting the sway bar allows the lower control arm to drop down and makes lots of space.
________
Gm foods
Old Jul 15, 2008 | 07:50 AM
Jayd41's Avatar
Linky no worky!
Old Jul 15, 2008 | 08:31 AM
RK's Avatar
RK
It's Not Easy Being Green
Originally Posted by Jayd41
Linky no worky!
https://www.rx8club.com/series-i-do-yourself-forum-73/robin-yang-diys-150346/
Old Jul 18, 2008 | 09:23 PM
Jayd41's Avatar
Thanks!!!
Old Aug 8, 2008 | 05:52 PM
IMO the easiest way is not to undo the lower control arm, but to undo the upper control arms, which then doesn't mess with the alignment and is also easier to get the rear shock/spring assembly in and out
I'll probably be doing this next week and will try to do step by step pics and text for a DIY thread
Old Aug 9, 2008 | 12:49 AM
wow,
nice post. am going to be doing the same in the next week or two.. i hope this is a helpful as you sway lower rad bracket post!
Old Mar 19, 2014 | 11:16 PM
MRmanDUDE11's Avatar
ugh links don't work! I'm stuck trying to get the stock strut off.
Posted From RX8Club.com Android App
Old Mar 20, 2014 | 04:45 PM
Williard's Avatar
Dark Moderator
M A Z D A This should help MRmanDUDE11
Old Apr 13, 2014 | 09:54 PM
Warrior777's Avatar
TeamRX8 you ever get around to making the DIY for unbolting the upper control arm?
jay_tibo
22
Sep 13, 2016 08:10 PM
blackbirdrx8
Aug 11, 2015 07:45 PM
AussieGray
Jul 16, 2015 03:58 AM
