Need some help figuring out offset for rims...
Old Apr 5, 2007 | 09:12 PM
R.P.M.'s Avatar
Rebuilds anyone?
Ok everyone, I'm looking to get a set of aftermarket 18" or 19" rims for my 8. They are staggered so I'm going to need some tire/rime guru person to help me see if the offset for these rims will fit.
The first set is 18x8 (fronts) 18x9 (rear) - both have an offset of 38mm
The other set is 19x8.5 (fronts) 19x9.5 (rear) - fronts have a 20mm offset and the rears have a 30mm offset.
Which set will fit the 8 without rubbing anything? I dont mind putting wheel spacers and long studs in to make them clear the calipers or anything like that.
Thanks !!
Old Apr 5, 2007 | 09:30 PM
ac3mastuh's Avatar
Got Ings?
im no guru but I know what works and what doesn't
the 18" combo would probably work with no problem
the 19" combo's offsets are wayyyy to low for the 8, ive seen a few guys run a +22 front wheel but even that is a really tight fit, i don't think the rear will even be possible to fit.
the rims make a bit of a difference on fitment but alot has to do with the tire choice
Old Apr 5, 2007 | 10:03 PM
Easy_E1's Avatar
Your first choice,,,
FRONT 18x8 38mm offset
Current Wheel Specs: Width 8 inches Offset 50mm
New Wheel Specs: Width 8 inches Offset 38mm
inner position: 12mm MORE
(the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 12mm
(position of the outside edge of the wheel)
_______________________________________________-
REAR 18x9 offset 38mm
Current Wheel Specs: Width 8inches Offset 50mm
New Wheel Specs: Width 8inches Offset 38mm
Inner Clearance: 1mm LESS
Outer Position: EXTEND an extra 25mm
Your second choice ,,,,,,,
Front,,, 19x8.5 offset 20mm
Current Wheel Specs: Width 8 inches Offset 50 mm
New Wheel Specs: Width 9.5 inches Offset 38 mm
Inner Clearance: 24mm MORE
Outer Position: EXTEND an extra 36mm
Rear,, 19x9.5 offset 30
New Wheel Specs: Width 9.5 inches Offset 30mm
Inner Clearance: 1mm MORE
Outer Position: EXTEND an extra 39mm
Their's your answer.
Old Apr 5, 2007 | 10:59 PM
spigot52's Avatar
good tool
http://www.1010tires.com/WheelOffsetCalculator.asp
hufflepuff
May 30, 2016 10:45 AM
duworm
Oct 1, 2015 04:57 PM
Quiggs321
Sep 30, 2015 05:34 PM
