Flex-a-lite install
Old Mar 30, 2007 | 04:09 PM
whoneedspistons's Avatar
Flex-a-lite install
hey does anyone have any knowledge on what wires on the stock radiator fan plugs are power and ground, basically the wiring diagram? i dont want to tear it apart and then try and test it.... i am trying to hard wire my flex a lite fans into the stock plug and i just need that little tad bid of info
once i have that info i will do a diy if you guys are interested
Old Mar 30, 2007 | 06:45 PM
O'Renesis's Avatar
Check page 26 in 'electrical' section on this on-line PDF manual.
http://www.hi-impact.org/ryang/modif...8_manuals.html.
Be aware that the fan motors sometimes run in series as well as in parallel. I assume they only run at full speed (parallel) if the coolant temperature is very high. There are 3 relays used to achieve this.
Old Mar 30, 2007 | 06:52 PM
rotarygod's Avatar
What are you running a flex-a-lite fan on? Please don't say the radiator! I've used 2 of them on RX-7's. Both of them melted down ni less than 6 months. The stock fans pull more than enough air and much more than a flex-a-lite fan. If you are wiring up a couple of little ones to an oil cooler then I'd understand.
Old Mar 30, 2007 | 06:57 PM
O'Renesis's Avatar
For both cooling fans to run in series only relay No.1 must be energised. When relays No2 and No.3 are also energised both fans run at full speed. Basically this means that fan No.1 gets its ground connection when relay No.2 is energised. Fan No.2 is permanently grounded. Hope that helps?
Old Mar 30, 2007 | 09:59 PM
well i am running them on the rad... i have used them on other cars one being boosted and never had any problems.... they flow more then stock and should help keep things cooler with the addition of the turbo system in a few months... o'ren thanks for the link
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
