Squeaking/whistling noise (not the brakes)
Old Mar 29, 2007 | 07:51 PM
Spazzychaz's Avatar
Spazzychaz
I just recently bought my 04 gt 6spd. I have since put on around 1k miles to make it a total of 9k miles. I have noticed that when I am around 3k rpms there is a high pitch whistling noise if you start to depress the gas. I only notice it just over 3k rpms and most prominently in 4th gear. By the way it is not the brake squealing noise.
Also I notice when down shifting there is a weird derevving noise the transmission makes.
Again as I am a new owner to the Rx-8, I am not sure if these are common sounds or if there is something wrong.
Thank you for the help any information is helpful.
Old Mar 29, 2007 | 08:42 PM
DarkBrew's Avatar
Extraordinary Engineering
Well the rotary makes all kinds of interesting sounds. My sister even asked me if the car has a turbo! You should hear the transmission with a short sifter and a Voodoo ****. Just enjoy the symphony. Hint: It's better with the windows down!
Old Mar 30, 2007 | 10:36 AM
Spazzychaz's Avatar
Spazzychaz
Thank you for the info? Any other input as well would be appreciated.
Old Mar 30, 2007 | 10:45 AM
MazdaMonkey's Avatar
Resident Monkey
When stopped, put the car in neutral and rev the engine a little bit. The rotary should whistle a little bit (probably up to and around 3500 rpms). If that is the same sound you are talking about then you car is fine.
Old Mar 30, 2007 | 11:44 AM
zoned's Avatar
rotary user
sounds like intake whistle to me
Old Mar 30, 2007 | 01:45 PM
MNShinka's Avatar
Spread it on!!
I occasionally hear a (metallic?) whistle at WOT @ 4500-5000rpm in gears 2-4. It can be a bit loud... at first I thought it was some kind of shift buzzer.
Is that what you are talking about? Does this happen to anyone else? Dealer at one point said it was "the intake opening up or changing positions". Is not the intake always at the same position?? weird...
Old Mar 31, 2007 | 03:39 PM
Resident Monkey
The manual transmission RX-8 has a 3rd intake that opens up around that RPM range to give it the extra power over the automatic.
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
