short shifter...
Old Mar 26, 2007 | 09:34 AM
Mikeluvs8's Avatar
short shifter...
for those of you with short shifters, which one do you recommend and post comfort compare to stock.... please post link of site for best prices. thanks!
mike
Old Mar 26, 2007 | 10:03 AM
Aero8's Avatar
AFE/RP short shifter
http://www.axialflow.com/products.htm
I love it. The car is more fun to drive to me. There is some tranny noise let in through it, but it is not horrible and you will like the feel of the closer shifts.
Old Mar 26, 2007 | 10:04 AM
GeTcRuNk's Avatar
http://www.axialflow.com/products.htm...should have came this way stock...can't go back
Old Mar 26, 2007 | 11:52 AM
NgoRX8's Avatar
yes go for the axial flow short shifter. some may not like it because the shifter is more stiff, but it makes it very notchy and exact so it will push into gear everytime.
Old Mar 26, 2007 | 12:31 PM
GeTcRuNk's Avatar
true that NgoRX8...now that I think about it...I haven't grinded a gear except reverse since my stock shifter
Old Mar 26, 2007 | 12:44 PM
mysql101's Avatar
there is really only one sts, it's the afe version. they based it off the mazdaspeed sts, but the mazdaspeed throws aren't as short, also the ms version costs more. so it's a no brainer.
Old Mar 26, 2007 | 12:57 PM
MrSuicideDoor's Avatar
clutch burner
how much is it installed?
Old Mar 26, 2007 | 12:58 PM
mysql101's Avatar
it's about $260, you install it yourself.
Old Mar 26, 2007 | 01:00 PM
Aero8's Avatar
I've grinded, but it was operator error
It does make it easier to get into gears than the stock shifter.
Old Mar 26, 2007 | 02:27 PM
LabDad's Avatar
Doggie Style :)
Installation is a piece of cake, even a caveman can do it.
Old Mar 26, 2007 | 02:54 PM
GeTcRuNk's Avatar
took me about a half hour to do...taking the console apart is the only annoying part...there is a do it yourself somewhere on the forum...search for it
Old Mar 26, 2007 | 05:23 PM
deadphoenix52's Avatar
meh.
i have the afe shifter and put it in myself. very easy. much better than stock.
Old Mar 26, 2007 | 06:07 PM
the only hard part is those @$%%&U&)%(&&_$ing wire holders that are stuck on the top of the threads...
Old Mar 26, 2007 | 06:15 PM
AdRoCK3217's Avatar
Rotary Superstar
Swoope, I don't know why, but I found those to be SO easy, especially after all the fuss I hear about them. I just took a screwdriver that was very thin (length and height) and moved 1 of the little pieces inside out of the way, pops right off.
Old Mar 26, 2007 | 06:20 PM
dont get me wrong. i have it figured out now... two pair of small needle nose one on each side. squeeze and bamm, done.. but the first time...sucked.
btw, i dont think i put them back on the threads last time..
Old Mar 26, 2007 | 06:39 PM
Phantom Menace's Avatar
II SOCIETY
Install is cake. I can put one in or take one out of an 8 in under 15minutes using ONLY a phillips head screwdriver and 10mm socket. Unlike other cars, the 8's shifter drops right in without having to go under the car! You can do it all from the driver's seat. Cake, I tells you! And I'm not a mechanic...
Old Mar 26, 2007 | 06:58 PM
+1 Afe
Old Mar 26, 2007 | 08:18 PM
Mikeluvs8's Avatar
thanks for the feedback guys, i guess af it is.
Old Mar 26, 2007 | 08:30 PM
DarkBrew's Avatar
Extraordinary Engineering
You won't regret it.
Old Mar 27, 2007 | 02:57 AM
california style's Avatar
Londons Yellow Peril
yeah it was my first mod and i still love it...
like some1 said before, its like the stock one SHOULD be.....
Old Mar 27, 2007 | 03:16 AM
chickenwafer's Avatar
Nope
Isn't afe and Mazdaspeed the only vendors that produce a short-throw shifter for the 8?
Old Mar 27, 2007 | 10:46 AM
they are the only ones i have seen.
Old Mar 28, 2007 | 01:35 AM
Nope
thanks, swoope- just making sure there aren't other options out there I wasn't aware of
poacherinthezoo
Aug 3, 2016 11:01 PM
Evan Gray
Nov 24, 2015 01:00 AM
