Flashing CEL while doing 100?
Old Mar 24, 2007 | 03:01 PM
savedsol's Avatar
Carbonormous
CEL flashed about 6 or so times until I got off the gas. I was going quite fast. What on earth? I did a search for CELs and haven't found anything except a couple of misfire threads? Could that be me?
Old Mar 24, 2007 | 03:02 PM
Xantium's Avatar
Unregistered User
I always get the airbag light flashing when break tripple digits, i thought that was pretty ironic but its supposed to be becuase of resistance.. its a tsb
Old Mar 24, 2007 | 04:40 PM
Go48's Avatar
Could be. Have the dealer pull any codes that may be stored in the ECU. Random misfires apparently are not uncommon when getting on it. May be a coil or spark plug problem.
Old Mar 24, 2007 | 05:14 PM
Imidazole's Avatar
That happened to me.
First big run to 130+, and of course CEL starts to blink. As if you're not a bit on edge and hyped up (aka scared) from the speed, a CEL doesnt give you confidence either!
In my case, it was a bad coil or misfire. Because after that, it ran like ****. It couldnt keep up with highway speed. It eventually 'fixed itself', but the dealership replaced a bad coil.
Old Mar 24, 2007 | 05:54 PM
MX6_2_RX8's Avatar
A nice step up!!!
It can happen if you are below 1/4 of a tank of gas. It uses it faster than it can suck it in.
Old Mar 25, 2007 | 07:40 AM
savedsol's Avatar
Carbonormous
1/2 tank.
Old Mar 26, 2007 | 07:34 PM
RxJaye's Avatar
The MIL (CEL) only blinks if a misfire that is bad enough to hurt the catalyst is happening, Happens when the engine goes lean, this overheats the cat. Can actually cause it to explode or melt.
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
