500hp 13b
Old Mar 21, 2007 | 01:06 PM
ricky356's Avatar
500hp 13b
i got the new turbo mag this month and on the cover it had a rx-7 equiped with a 1.3 liter 13b. im new but this is the same engine we have in our rx-8 right? if so why are there no 500+ hp rx8's running around ...unless i havent heard about it.
just wanted to know if anyone has seen this and if they have why is it necesary to swap to a 20?
thanks
rick
Old Mar 21, 2007 | 01:10 PM
I8U's Avatar
I8U
Anyone else wanna handle this one? All I'm gonna say is...yes and no!
Old Mar 21, 2007 | 01:16 PM
Digital_Damage's Avatar
No not the same engine.
but 500hp will be coming.
Old Mar 21, 2007 | 01:19 PM
ricky356's Avatar
what do we have a 13-a?
Old Mar 21, 2007 | 01:25 PM
expo1's Avatar
He's as bad as Can
13B RENESIS
Old Mar 21, 2007 | 01:34 PM
Mazda-Rati's Avatar
the WANKEL made me do it
the differences of the 13B and the 13B renny are posted everywhere on the internet and on this forum.
If you care about your feelings....don't come back to this thread. I think a lot of flaming is about to take place.
Old Mar 21, 2007 | 01:38 PM
rotarygod's Avatar
Go easy on the guy. It's an honest question.
Old Mar 21, 2007 | 01:39 PM
rotarygod's Avatar
Here's one that did 711 hp and 566 ft lbs of torque.
http://www.rx7club.com/showthread.php?t=633482
Old Mar 21, 2007 | 01:47 PM
Red Devil's Avatar
I'd be happy with seeing a proven, reliable 400whp Renesis.
GT34's Avatar
Wanna touch my wankel?
This is all you need to know my firend
The reason the typical rx8 owner isn't running around with 500bhp, is because he'd be rebuilding his engine every 20k. Judging by the turbo mag you're looking at, they're probly pumping a lot of air into that engine. Only a handful are capable of properly tuning the 13b. It's not reliable enough to do.
If you wanna get technical about our engines they are 13b. It even says so on the side of the engine. However they're not the same as the previous generation rx-7s 13bew. The apex seals and the porting is done differently. However the rotars housings are mildly the same. Please read before attempting to flame me. http://www.mazdamaniac.com/direct_dl.htm
Old Mar 21, 2007 | 01:54 PM
rotarygod's Avatar
Just for the record, the 711hp 13B in the link above is a streetported 13B using 9.0:1 compression ratio. He's got Atkins apex seals (which I wouldn't use but that's just me) that are cryotreated. He's also got a Guru Racing eccentric shaft that has the center bearing which I've been preaching about for some time now. He's got a stock intake manifold (and admits it's holding back power), a big single turbo, large intercooler, and some damn good tuning. The C16 gas helps too.
Out of the above list about the only thing that really helps with the strength of the engine is the eccentric shaft. The rest of it was really a result of good tuning. Keep in mind he's also got a full point lower of compression. High compression like the Renesis at 10.0:1 will reach it's limits much sooner on the power game. It will still be over 400 hp though with good tuning.
I'm not sure we'll see 500 hp out of a Renesis without some good money being spent internally on the engine. You don't see that out of a 13B on a stock engine. Yes it has been done but there are always extreme cases out there. Most can't do it.
Old Mar 21, 2007 | 03:27 PM
rx8frank's Avatar
White RX8 R3
To get those number some of them run on the 13B-REW of the past cosmo....I know two guys who own rx-7 have the 13B-rew in them and One of them pull 450hp out of it. Here his link...it's in french but most of it's mods are written in english...
http://rotaryrocket.monchar.com/
Old Mar 21, 2007 | 08:19 PM
ricky356's Avatar
[QUOTE=Mazda-Rati]the differences of the 13B and the 13B renny are posted everywhere on the internet and on this forum.
If you care about your feelings....don't come back to this thread. I think a lot of flaming is about to take place.[/QUOTE
Care about my feelings? how old are you?
thank you to everyone who took the time to school me.
Rick
Old Mar 21, 2007 | 08:24 PM
Cody Red's Avatar
always filling [the c]up
yeah, we have a 13b renesis, and that 500hp 13b you're reading about is a 13b-rew
it's all good, a lot of us still don't know EVERYTHING about Rotary engines. we all gotta start somewhere. I've seen 700hp out of a 13b-rew, but i'm more than sure it won't last more than 10k miles. but having that much power isn't your typical daily driver anyways.
-Cody
Old Mar 21, 2007 | 11:20 PM
Mazda-Rati's Avatar
[QUOTE=ricky356]
Rick
Does age really reflect maturity level?....silly question though, but I'll answer, I'm 12 years old
A very good sticky to read is here..https://www.rx8club.com/series-i-tech-garage-22/rotary-specific-sae-papers-105067/ It may answer some of your questions
Old Mar 22, 2007 | 01:57 AM
Detrich's Avatar
幹他媽!
thanks for answering his question. i learned a lot from reading this thread too.
Old Mar 22, 2007 | 05:41 AM
california style's Avatar
Londons Yellow Peril
Is there any reason why Mazda called the Renesis a 13b?
especially as they changed the ports etc, which is quite a fair change from my understanding...
Why not a 14B or something?
Old Mar 22, 2007 | 10:45 AM
rotarygod's Avatar
13B is technically what the engine is. We throw the terms 13B and Renesis around separately since it's easier to understand which engine we are talking about. We generally refer to a 13B engine s a side intake port, peripheral exhaust port configuration while we think of a Renesis being a side intake and exhaust port engine. What about an all peripheral port configuration? We still call this a 13B. The Renesis is a 13B based on how Mazda names their rotary engines. Everytime a dimension internally changes in regards to displacement, they give it a new name. "13" refers to the displacement which is 1.3 liters. The 12A engines were 1.2 liters. The letter designation generally (but not always) refers to the generation of this size range. "A" would be the first incarnation of that engine size. Again, generally as they have broken that rule before.
There was a 13A engine. It was only available in one car for 2 years. That was the Luce and it was the only front wheel drive rotary powered Mazda ever made. That was in the 70's. That engine differed from the 13B in that it's rotors were taller but not as wide. Think of this engine as the stroker of rotaries. It's overall displacement was 1310 cc which is a fraction larger than the 13B at 1308 cc. Mazda just rounds the numbers so they both appear as "13". When Mazda changed to the wider rotors that had the same shape as the 12A rotors, they changed the name to reflect the second incarnation of this size range which was naturally a "B".
The engine size hasn't changed at all with the Renesis. Only the porting has so on these grounds it is still a 13B. Just a 13B with different porting. This is no different than an all peripheral port engine being called a 13B as well. For the sake of clarity we do use the terms independently when referring to them though.
Old Mar 22, 2007 | 11:21 AM
GT34's Avatar
You are the rotary god
Old Mar 22, 2007 | 12:43 PM
rotaryWizard's Avatar
RenesisRocket
what would if you were able to lower compression on the renesis, would boost and hp be more accessible?
Old Mar 22, 2007 | 03:48 PM
Red Devil's Avatar
Absolutely. Now the trick is getting lower compression rotors that work with the Renesis.
Ian_D
Rotary Swaps
26
Jan 21, 2017 02:23 PM
Ian_D
Rotary Swaps
Sep 23, 2015 11:22 AM
Fickert
Sep 9, 2015 01:21 PM
RX7.9
Jul 20, 2015 12:01 PM
