Wierd Groniding sound when pulling out after installing a new clutch and ss line
Old Mar 20, 2007 | 11:38 PM
SWVA_RX-8's Avatar
Purge Addict
Question Wierd Groniding sound when pulling out after installing a new clutch and ss line
I have a wierd grinding or rubbing sound from the clutch when I am pulling out but not once thw clutch is full let out and it doesn't do it it in any other gears! I just replace the clutch and Pressure plate and when with a ss clutch line I have quite a bit of free play on the the pedal shuld I bleed the slave some more or should I try something else???
Old Mar 21, 2007 | 01:51 AM
peterisurhero's Avatar
peterisurhero
dude... no offense, but learn how to type. i can't understand what your trying to say. hahah once you clarify, i'll try to help
Old Mar 21, 2007 | 09:57 AM
8is>enuff's Avatar
Bland
Chatter? With a new clutch you'll be more likely to have a bit of chatter when taking off, at least until the clutch is broken in.
Old Mar 23, 2007 | 03:50 PM
kwescott's Avatar
One ball, corner pocket
+1 for breaking in the clutch, things should improve.
Dokuji
Nov 1, 2016 02:51 PM
BigMikeATL
May 26, 2016 12:31 AM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
