LED center tail light w/ reverse lights
Old Mar 17, 2007 | 02:12 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I've always been disapointed with our tail lights....they should have been led stock I thought i'd give it a try myself. I used Eight 25000mcd red leds for the brake light and fourteen 30000mcd white leds for the reverse lights.
Attached Thumbnails LED center tail light w/ reverse lights-img_1902.jpg   LED center tail light w/ reverse lights-img_1906.jpg   LED center tail light w/ reverse lights-img_1909.jpg
Old Mar 17, 2007 | 02:17 AM
Started off with some blank pcb board.
Attached Thumbnails LED center tail light w/ reverse lights-img_1885.jpg   LED center tail light w/ reverse lights-img_1887.jpg   LED center tail light w/ reverse lights-img_1891.jpg   LED center tail light w/ reverse lights-img_1886.jpg   LED center tail light w/ reverse lights-img_1888.jpg
Old Mar 17, 2007 | 02:20 AM
Added the reverse leds.
Marking where to drill the wholes:
Attached Thumbnails LED center tail light w/ reverse lights-img_1889.jpg   LED center tail light w/ reverse lights-img_1892.jpg   LED center tail light w/ reverse lights-img_1893.jpg   LED center tail light w/ reverse lights-img_1895.jpg   LED center tail light w/ reverse lights-img_1896.jpg
Old Mar 17, 2007 | 02:23 AM
Running the reverse wire:
Soldered to the reverse light on the tail light:
Attached Thumbnails LED center tail light w/ reverse lights-img_1897.jpg   LED center tail light w/ reverse lights-img_1899.jpg   LED center tail light w/ reverse lights-img_1900.jpg   LED center tail light w/ reverse lights-img_1903.jpg   LED center tail light w/ reverse lights-img_1904.jpg
Old Mar 17, 2007 | 02:24 AM
Attached Thumbnails LED center tail light w/ reverse lights-img_1905.jpg   LED center tail light w/ reverse lights-img_1901.jpg
Old Mar 17, 2007 | 02:54 AM
BoosTED's Avatar
Wow that is resourceful.
Only bad thing I could think I see with this is someone could mistake the white backup light for you still pressing on the brake and not yield if you are backing up in a parking lot. Since it is in the standard brake light spot when you put it in reverse.
It looks plenty bright though so maybe not.
You could mount some stealth LEDs into the lower section on the rear bumper as well.
Old Mar 17, 2007 | 02:56 AM
lol, the person would have to be colorbind and a moron if they thought that.... the leds are brighter then hell.
Old Mar 17, 2007 | 03:03 AM
BoosTED's Avatar
That's true, if I was to see someone's backup lights on I pretty much yield regardless. (The majority of accidents occur in parking lots).
Old Mar 17, 2007 | 03:45 AM
ok im next up in line for this mod! thank god rotary rasp lives mins away from me
Old Mar 17, 2007 | 04:00 AM
BoosTED's Avatar
I admire the attention to lighting you guys have.
It is inspiring.
Old Mar 17, 2007 | 05:27 AM
Wing5's Avatar
Any pics? Useless w/o em~
Rodger's skills pwn j00 ........ pwn me too ^^;
Nice job Rodge!
Old Mar 17, 2007 | 10:17 AM
Spin9k's Avatar
Momentum Keeps Me Going
Nice job RR! Good to see some down and dirty/electronic & soldering skills put to use. Perhaps you should add your schematic and parts list/source to make a real DYI out of it for others to follow!
Old Mar 17, 2007 | 10:48 AM
RA-Eight's Avatar
Scuderia
That's nice. ahem...group buy! pretty please?
Old Mar 17, 2007 | 12:27 PM
This solution is for the red LEDS. 4 x 1 array uses 4 LEDs:
+----|>|----|>|----|>|----|>|---/\/\/----+ R = 330 ohms (x2)
These leds have a foward voltage of 2.0 volts and a max current of 20 millamps.
Each 330 ohm resistor dissipates 132 mW. The code for 330 is orange orange brown. ¼W resistors within spec. The diodes dissipate 160 mW. Total power dissipated by the array is 292 mW and the array draws current of 20 mA from the source.
Old Mar 17, 2007 | 12:31 PM
This solution is for the white LEDS.
+----|>|----|>|----|>|---/\/\/----+ R = 270 ohms
+----|>|----|>|---/\/\/----+ R = 470 ohms
Each 270 ohm resistor dissipates 108 mW and each 470 ohm resistor dissipates 188 mW. The color code for 270 is red violet brown and 470 is yellow violet brown. This array draws current of 20 mA from the source.
Old Mar 17, 2007 | 01:21 PM
Attached Thumbnails LED center tail light w/ reverse lights-img_1910.jpg   LED center tail light w/ reverse lights-img_1914.jpg   LED center tail light w/ reverse lights-img_1913.jpg
Old Mar 17, 2007 | 03:01 PM
jstkilntim's Avatar
resU deretsigeR
Nice!
Old Mar 18, 2007 | 05:31 PM
Aipex8's Avatar
X e p i A
Looks great, Rotary Rasp. I've been thinking of ways to do something similar, except I want to get rid of the red lense all together. I happened on these pics from a French RX-8 forum and really want to do something like this. Unfortunately I don't speak French, so I don't know any details. Here are the pics though:
Another easy way to do this would be to use one of PIAAs rear LED fog lights. The Deno 3 has almost the exact same dimentions as our 3rd brake light. I'm hesitant to spend $70 on it though and find out it won't work for some reason.
Old Mar 18, 2007 | 05:59 PM
Spin9k's Avatar
What's the URL, it can more than likely be figured out
Old Mar 18, 2007 | 08:52 PM
Aipex8's Avatar
X e p i A
http://www.rx8france.com/forum/setopic_6476-led.html
I ran it through google translator and it really didn't help much. I joined the site and sent the user a PM, I don't know if he speaks English or not. It looks like he might actually be selling them though.
Old Mar 18, 2007 | 09:53 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Take a look at this thread. I know some people were searching for a way to even out this design as just one light in the center tends to fade out on the sides. Maybe some combo between yours and this one would work good.
All a matter of opinion I guess though.
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-3rd-brake-light-rx-8-logo-mod-21092/
DT
Old Mar 19, 2007 | 12:42 AM
thebiggdaddy's Avatar
some good stuff.
Old Mar 19, 2007 | 01:24 AM
chickenwafer's Avatar
Nope
do you reckon if you used some super-small LED's you could write "RX-8" with the LED's on the circut board, so when you brake it lights up "RX-8"?
I know there is that cover for it, but this would be extra trick IMO. I guess it would look a little "blocky" and not as curvey as the RX-8 script is written in
Dave
Old Mar 19, 2007 | 05:56 AM
Dave
It could be done with some small 3mm leds. I don't think it would turn out that great. It would be very hard to make it look right (font wise)
Old Mar 19, 2007 | 05:58 AM
That looks great! What don't you like about the red plastic? It would be very easy to paint another color if desired. I'd like to know what they are using as reflectors for the leds.
