CEL after gutting cat
Old Mar 13, 2007 | 06:34 PM
RXSeven1's Avatar
dorito spinner
After about a half hour of cruising after gutting the cat I got a CEL. So I reset the ecu, and it seems to be fine but.....
In the 8....when the CEL illuminates, does it cause the car to run differently? meaning am i at a higher risk of breaking stuff/running lean with the CEL on other than off. Or is the CEL just telling me somethings wrong.
Old Mar 13, 2007 | 06:46 PM
j67345's Avatar
Probably depends on what the CEL is for....some are caused by the fuel cap not sealing, so no problem...others I'm sure could mean something bad
Old Mar 13, 2007 | 07:39 PM
expo1's Avatar
He's as bad as Can
Didn't you think the car would know you gutted the CAT? But other than NJ Inspection and police that don't like the noise your car sould run ok. Now if you did a hack job at gutting the CAT all bets are off.
Old Mar 13, 2007 | 08:10 PM
MazdaManiac's Avatar
Nice procedural discipline.
Old Mar 13, 2007 | 08:20 PM
lurch519's Avatar
www.evoperform.com
LOL, on a different note, love the new avatar MM
Old Mar 13, 2007 | 08:34 PM
RXSeven1's Avatar
dorito spinner
I heard that gutting that cat as opposed to a midpipe will reduce the chance of CEL
My best friend has a 8 too. When i need to pass inspection Ill borrow his Cat.
Gutting the cat is insignificantly louder than stock.
Old Mar 13, 2007 | 08:39 PM
RXSeven1's Avatar
dorito spinner
Originally Posted by mmats69
oh yea, you just voided your warranty in its entirety. period.
WHY is everyone so friggen anti and negative? i thought this through before i did it. As i stated, I have access to more than one spare cat. If the car breaks, i switch it. Additonally, my car will be out of warrenty in about a month due to the fact I have 55,xxx miles.
Old Mar 13, 2007 | 08:48 PM
We think it's funny that you were surprised that you have a CEL with no CAT
There are only about 300 threads on this already.........
Just don't ask about an O2 fooler next...or we will reload!
Old Mar 13, 2007 | 09:22 PM
who'd a thunk it?
Old Mar 13, 2007 | 09:45 PM
if the CEL is for O2 sensor, then yes it will affect performance. the ECU senses too much emmissions so it will pull timing to get back in compliance.
Uh, no.
Old Mar 13, 2007 | 10:38 PM
RXSeven1's Avatar
dorito spinner
I've read all the threads, i searched, i have experience with rotarys.
The reason i asked is because the FD will go into some thing called limp mode. i didnt know whether the advanced ecu of the 8 would do something like that.
Old Mar 13, 2007 | 11:21 PM
AdRoCK3217's Avatar
Rotary Superstar
if the CEL is for O2 sensor, then yes it will affect performance. the ECU senses too much emissions so it will pull timing to get back in compliance. put a high-flow cat on there and be done with it. oh yea, you just voided your warranty in its entirety. period.
I'm almost 100% positive you are completely false. As far as I know, the first O2 sensor is where all the timing advance/retard happen. At the beginning of the exhaust stream (note: pre-catalytic converter) is the only place in the exhaust you can get an accurate reading on AFR, temperature, etc.
The second O2 sensor is AFTER the first catalytic "beehive" section..and would get skewed readings, which could not be used to calculate anything regarding engine performance.
Not to mention, only a completely retarded person (not pointing any fingers here..) would think that the warranty is completely void. That's just not knowledgeable. Under the Magnuson-Moss warranty act, the addition of after market parts alone does not mandate a void of ones warranty. Only if the car maker can prove (at least, to an undereducated judge) that this part caused a problem on your car, can they void the warranty on the part of the car that THAT piece applies to.
If your after market cat clogs up, and caused the engine to fail, they could legally void the warranty on your engine, all of its components, and possibly the rest of your drive train. But it would not void your entire warranty.
Old Mar 14, 2007 | 10:45 AM
knight7's Avatar
just put the O2 censor back to the pipe and call it a day. or go more technical and erase the cel from the comp.
Old Mar 14, 2007 | 03:22 PM
AdRoCK3217's Avatar
Rotary Superstar
I'm going to go one step further with mine. Going to take a tip from the EVO guys use 2 spark plug defoulers.
Old Mar 14, 2007 | 03:29 PM
StealthTL's Avatar
Metatron
Cool This ain't no stinkin' Evo.....
OK guys, reload.
S
Old Mar 14, 2007 | 04:27 PM
Mazda-Rati's Avatar
the WANKEL made me do it
if the CEL is for O2 sensor, then yes it will affect performance. the ECU senses too much emmissions so it will pull timing to get back in compliance. put a high-flow cat on there and be done with it. oh yea, you just voided your warranty in its entirety. period.
Well, your "PERIOD" crap backfired on you. The o2 sensor responsible for that particular CEL has nothing to do with performance.
From Racing Beat's website:
Racing Beat offers a full 304-stainless steel catalytic converter replacement pipe for RX-8 racing applications. This mandrel-bent 3” OD racing pipe is a direct bolt-on replacement for the stock catalytic converter section. This pipe utilizes a genuine OEM rear mounting flange for a secure fit to the stock (or an aftermarket) exhaust system. (See photo below.) The race pipe is equipped with a sensor fitting for the oxygen sensor. (Note: Placement of the sensor in the pipe will cause the “check engine” light to be illuminated, but performance and engine systems will not be affected.)
Old Mar 14, 2007 | 07:48 PM
AdRoCK3217's Avatar
Rotary Superstar
Originally Posted by StealthTL
OK guys, reload.
S
What do you mean by the "This ain't no stinkin' Evo" comment?
Old Mar 14, 2007 | 09:49 PM
RXSeven1's Avatar
dorito spinner
Pwnd
Old Mar 15, 2007 | 10:42 PM
mmats69's Avatar
93.5 octane
oh well, can't be right all the time.
Old Mar 16, 2007 | 08:28 AM
AdRoCK3217's Avatar
Rotary Superstar
Right, so don't act like you word is law.
Old Mar 16, 2007 | 08:44 AM
StealthTL's Avatar
Metatron
Cool Stinkin' Evo comment.....
The ECU has a check mode that will find an O2 fooler - this isn't the primitive setup used by an Evo.
A couple of defoulers will probably work for an Evo, but when the ECU checks, the CEL will come back.
....the little 'fooler chip' won't work either, bills to prove.
S
Old Mar 16, 2007 | 11:42 AM
mmats69's Avatar
93.5 octane
didn't say it was. just owning up to my error
Old Mar 16, 2007 | 12:49 PM
AdRoCK3217's Avatar
Rotary Superstar
S
Well, since your so versed on the subject, I figure I should direct my question to you:
With my resonated mid pipe, my CEL comes on about 50-75 miles after I reset it. If I were to clear the CEL right outside of emissions, and then go inside for the test (CEL is not on), will I pass? Emissions in MD only mandate a OBDII test, where if your CEL if on you fail.
Old Mar 16, 2007 | 01:11 PM
However, a 1/2 watt, multi-turn potentiometer will work.
Old Mar 16, 2007 | 01:19 PM
StealthTL's Avatar
Metatron
Cool Cel.....
(Sounds like MM has a fix that might work - it would respond to the fluctuations the ECU sends....)
Your scenario might work with an old OBDI car, but the OBDIIs keep a record of when the light was reset, and "TODAY 11:00am" might ring some alarm bells.
I'm not sure if it's after one or two "start cycles" that the computer stores a "pending" code, it will set a CEL if the fault re-occurs. That could be a fail too, depending on how sharp the tech is....
S
