Couple of n00b brake caliper questions, need some help
Old Mar 13, 2007 | 02:00 AM
Raptor2k's Avatar
Club Marbles Member
So I got around to painting my brake calipers today with duplicolor's spray paint....a pain in the *** but so far it looks good in the garage.
Couple of questions...
1). Stupid question maybe...is it okay to have some paint on the rotors? I mask taped as much as I could but some paint still got on the rotors, and I wiped them down, but theres still some on. Will it go away after some braking?
2). Do I really have to wait a whole 24 hours before driving? I gotta go out in about 14-15ish. The paint dries pretty quick from what I know...I could touch it after 5 mins and not get my fingers stained.
3). What's the torque setting on the lugnuts again? 87? Searching gave me different results...just looking for a definitive answer.
I used brake cleaner, sanded the calipers and hubs, painted the hubs, painted calipers. I'll get some pics up later.
Old Mar 13, 2007 | 02:56 AM
Cam's Avatar
Cam
this space for rent
1 Should be fine
2 I would drive
3 87 is correct
Old Mar 13, 2007 | 03:05 AM
1 a little is ok. but a lot will embed in the pads and be bad
2 likely not an issue
3 105 ft lbs.
Old Mar 13, 2007 | 12:26 PM
Raptor2k's Avatar
Club Marbles Member
lol at #3
Do I need a poll for that one?
Old Mar 13, 2007 | 12:42 PM
Raptor2k's Avatar
Club Marbles Member
Old Mar 13, 2007 | 12:46 PM
Napboy's Avatar
Sho'Nuff
#3. The stock specification is 87. However, some have noticed a clicking sound from the front wheels when driving at low speeds. The TSB issued my Mazda to correct that problem was to torque it to 105 (I don't know if that's the exact number, but that sounds right).
So, if you hear the clicking, 105. If not, 87.
Old Mar 13, 2007 | 12:55 PM
Raptor2k's Avatar
Club Marbles Member
Cool, thanks
Old Mar 13, 2007 | 01:29 PM
they raised the wheel lug nut spec to 108 lb-ft period, not just if you hear noise:
http://www.finishlineperformance.com...2-04-1301b.pdf
Old Mar 13, 2007 | 04:15 PM
RoXanneBlack8's Avatar
stop flooding ur engines
u should have completely removed the caliper and did it on a bench, if ur gonna half *** it and paint them, might as well half *** it properly.... not that im approving of the "mod" anyway.....
Old Mar 13, 2007 | 04:42 PM
Raptor2k's Avatar
Club Marbles Member
Didn't have the tools to take it off, don't see the problem masking everything and keeping it on. It looks perfect.
Old Mar 13, 2007 | 05:30 PM
dillsrotary's Avatar
jersey fresh
i did the same raptor, its not half *** at all.
Old Mar 13, 2007 | 05:45 PM
Mazdaspeed RX8 ver2's Avatar
i dont think its half assed as well. anyways, with all the questions being answered, your #3 should be at around 108 lb-ft.
did you post up any pics?
Old Mar 14, 2007 | 12:16 PM
Raptor2k's Avatar
Club Marbles Member
Was raining yesterday....I was glad to see the paint hold up when I've only let it dry for about half a day. Will get some shots...
Old Mar 24, 2007 | 02:19 AM
Raptor2k's Avatar
Club Marbles Member
Paint's holding up well.
But there's some minor squeeking going on in one of the back brakes, or both, can't tell...only happens sometimes at speeds around 40-50. Not sure what's causing it...
Old Mar 24, 2007 | 07:08 PM
Raptor2k's Avatar
Club Marbles Member
Old Mar 24, 2007 | 08:54 PM
RX8Carnage's Avatar
Nice Job I did mine too but i used the brush on type real easy to use and no overspray
Old Mar 24, 2007 | 08:57 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Me too.......brushed them on and took my time. Will post a few pics tomotrrow.
Old Mar 24, 2007 | 09:29 PM
llzjayarzll's Avatar
meow
howd you do the rotor housing without taking the rotor off?
did you just cover everything, then sand and spray the exposed part?
Old Mar 25, 2007 | 01:08 AM
Raptor2k's Avatar
Club Marbles Member
The hub of the rotor? Yup.
You also don't have to mask the entire thing....just enough to catch any overspray. My spray out of my duplicolor spray can was pretty tight and accurate.
I did get some paint on my rotors and thought by braking it would all come off...but I'm getting some minor squeaking like I said...I'll try using some brake cleaner on the rotors to get as much as I can off and see if that helps.
Or it could be I need new rear pads, I'm still on the factory ones at 34k miles.
Old Mar 25, 2007 | 06:24 PM
Mazurfer's Avatar
Painted dust shields black, Calipers blue, Mazdaspeed by Polak graphics, and the hubs/hats were already black because of the new rotors.
Attached Thumbnails Couple of n00b brake caliper questions, need some help-new_rims11.jpg   Couple of n00b brake caliper questions, need some help-new_rims1.jpg   Couple of n00b brake caliper questions, need some help-rx8-newpic.jpg   Couple of n00b brake caliper questions, need some help-rx8-newpic0.jpg   Couple of n00b brake caliper questions, need some help-rx8-newpic6.jpg
Old Mar 25, 2007 | 06:26 PM
Mazurfer's Avatar
Little bigger pic.
Attached Thumbnails Couple of n00b brake caliper questions, need some help-new_rims16b.jpg
Old Mar 25, 2007 | 06:27 PM
looks good. and check pm.
Old Mar 25, 2007 | 06:29 PM
Mazurfer's Avatar
No PM yet, unless you are just writing it.
DT
Warrior777
Jun 24, 2019 04:47 PM
UHATEIT
Mar 31, 2019 05:31 PM
seb16
Sep 15, 2016 12:20 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
