y'all know the 8 drinks the oil.
Old Mar 11, 2007 | 08:32 AM
reddevilwarrior's Avatar
I bought my car about 2 months ago, and probably filled up gas tank twice... (I go to school, I dont drive it unless I am home)
I turned the engine off, wait for 10 min. and get a dipstick.
And like oil is still at the full mark, I check over and over but its still there at same spot. It does not seem to decrease. I know you guys recommed to check dipstick every 2 times I fill up the tank or certain miles. I am over both of that, but my oil seems the same.
What the hell is going on?
I have spare oil in my trunk, but never used it yet.
Old Mar 11, 2007 | 08:38 AM
cajunrx8's Avatar
Rotary Crawfish
you anit runnin the **** outta it.
Old Mar 11, 2007 | 08:40 AM
tony_673's Avatar
...is it over yet?
The 8 doesn't "drink" oil, it sips it. You may not see a huge difference in oil level after two fill ups. It's still important to check every two/three fillups, but it's not going to be a drastic change. Nothing is wrong with your car. Mine is the same way.
If you don't notice a change after 5 or 6 fillups, I might be a little worried. Then again, if you aren't using any oil even after 5 or 6 fillups, you probably don't have a motor left! The metering pump in the 8 can go bad. (I found out the hard way! )
Old Mar 11, 2007 | 08:47 AM
New Yorker's Avatar
Ok, first off, you do realize the 8's engine is DESIGNED to inject a small amount of oil into the engine for the rotors. Saying "ya'll know the 8 drinks the oil" makes it sound like a) there's a design flaw causing excessive oil consumption, and b) the 8 uses a lot of oil. It doesn't—you might add a quart over 1,000 miles or so.
And though it's wise to check the oil every other fill-up, you'll find the oil level goes down VERY slowly, and you'll be adding oil very infrequently. In 8,500 miles I've added small amounts of oil maybe three times.
ZoomZoomH's Avatar
Mulligan User
check every 1500 mile or so, every 8 is a little bit different in terms of oil consumption rate.
Old Mar 11, 2007 | 09:37 AM
kartweb's Avatar
As it's been stated, the 8 injects a teeny tiny squirt a couple times every so often. Two things affect the consumption; Flash version and driver habits. The latest flash is said to use a little less oil to prolong plug life. The more revs per mile the more it burns per mile.
Generally I get about 2000 miles per quart, but most of my driving is highway. Some people get 1000 miles per quart.
I just had the latest flash put in and will be changing the oil today so I'll be watching consumption to see if there are any changes.
The CX7 gets about 2500 miles to a quart and the 5 doesn't seem to use any oil between the 3000 mile changes.
Old Mar 11, 2007 | 12:26 PM
Tamas's Avatar
Registered Lunatic
To the contrary - Mazda increased the amount of oil injected, to provide more lubrication and better protection to the engine.
Old Mar 11, 2007 | 12:31 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Yes that would be more accurate.
Checking every other fillup is a bit much. I do it about once a month and never had a problem.
Old Mar 11, 2007 | 12:36 PM
Thanks guys, I am just relieved that I am not in trouble...!
I will keep my eyes on it.
But it just seems it doesnt go down.
I will keep checking.
when you guys check the dipstick and you can see clearly it went down? before you need to add some more?
mdw1000's Avatar
I'll snap his neck.
I check mine every 500 miles, but at 10,000 miles i've only added about 4 quarts total (I get the oil changed every 5000 per mazda's recommendation). Once I see how the new flash changes consumption I'll probably switch to checking it every 1000.
I usually add some once it gets below the "half" mark on the dipstick.
How many miles do you have on your car so far?
Old Mar 11, 2007 | 12:39 PM
RotaryP7's Avatar
Seriously.. FML..
Well, I haven't changed my oil as of yet and I have about 2400 miles on..
Old Mar 11, 2007 | 12:42 PM
longfury's Avatar
Last time I heard...even for the piston engined guys...1Qt./3000miles is acceptable usage for any engine.
As always, every engine is different and your usage may vary.
Old Mar 11, 2007 | 01:01 PM
Spin9k's Avatar
Momentum Keeps Me Going
If you want to see the oil go down, just so as you know your engine is working correctly , spend some quality time in the 5-9K rpm range, favoring the ups and downs and spending more time in the higher up ranges. I mean not just running thru the gears, but relax and get used to running the car there. You can do it on the street, but it's more fun on the track, but either will work, you'll just be more obvious on the street runing in 2nd and 3rd. It's a lot of fun and really doesn't hurt anything, except your gas mileage .
If you do this, you could use as much as 1/2 to 1 qt every 30-40 miles. That lil metering pump will get a good workout that way!
Old Mar 11, 2007 | 01:43 PM
It has over a lil 11k.... when I bought it
I am not sure how much I put on... not a lot at all.
I don think that helps anything, does it?
lol
Old Mar 11, 2007 | 01:44 PM
longfury's Avatar
*makes mental note to pack lots of oil* It appears i will have an RX8 again soon and will be running in this rev range a lot on a few mountain excursions. Must remember to take a few extra quarts of oil.
Old Mar 11, 2007 | 01:58 PM
therm8's Avatar
Bummed, but bring on OU!
Each car's a little different, and everyone's driving habits are different. Once you figure out how much oil you use, it's easy to determine an interval. For instance, I have to add a 1/4-1/2 qt every 1500-2000 miles. Your mileage may vary .
Old Mar 12, 2007 | 08:01 AM
tony_673's Avatar
...is it over yet?
Oooh, I like therm8's avatar!
Old Mar 12, 2007 | 08:33 AM
Feras's Avatar
the Doctor
i usually don't make 750 miles without having to add an extra quart, and i premix as well lol every one of these 8s is different.
Old Mar 12, 2007 | 10:17 AM
Raptor75's Avatar
I average a quart every 750 miles. Best was a little over 1000 and worst was a little over 500.
My car gulps oil.
Old Mar 12, 2007 | 11:14 AM
04RX8man's Avatar
Rotary Powered Countryboy
Yeah you're fine u just don't drive that much! I've used a quart in like 1200 miles but I run it pretty hard a few times but i check it after every two or three fill ups after school or work usually. Good luck
tommy26Germany
Sep 29, 2015 10:33 AM
drlubell
Sep 26, 2015 11:58 PM
gnat42
Sep 16, 2015 08:47 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
