oil in the intake
Old Mar 4, 2007 | 04:01 PM
ricky356's Avatar
oil in the intake
hey guys,
took off my stock air box yesterday just to see how the intake was all put together cuz i was bored and noticed oil inside the rubber boot? or what looked like oil. what the hell? i have a 04 manual with 31000 miles.....help!
Old Mar 4, 2007 | 06:39 PM
Go48's Avatar
This has been covered in many threads over the past 3 years. Apparently it is not uncommon. I suggest you search and read some of the posts. There are a several theories on the cause(s). I understand that the latest model years have a solution built into the intake system. Maybe you can talk your dealer into installing an upgrade?
Old Mar 4, 2007 | 07:25 PM
ricky356's Avatar
yea i did a search and came up with a bunch of different stuff nothing really pertaining to a problem, il look some more tho. will this cause problems later? i read that someone busted there side seals and oil in the intake was a sign of that. if its just a common thing will it affect me when i go turbo?
Old Mar 4, 2007 | 09:41 PM
Raptor75's Avatar
I had the same problem and the dealer said it was because I was not using a funnel to fill the oil. It was true I was not. I started to use one and have so far not seen any oil in the air box. I plan to pull the system apart come summer to confirm.
Old Mar 5, 2007 | 07:01 AM
Go48's Avatar
As I mentioned, there are several theories on what causes this problem. For a complete picture you really need to spend the time to research and read the posts in this forum regarding oil in the intake system.
One thing that is of concern is that if the oil gets into the MAF/IAT sensor unit situated on the top of the intake pipe, engine performance may suffer--perhaps dramatically. If you go turbo, you will likely want to install a catch can. (There are threads on catch cans and cleaning the MAF/IAT sensor unit in the DIY section as I recall.)
Old Mar 5, 2007 | 09:22 AM
ricky356's Avatar
thanks
rick
gwailo
May 14, 2024 06:57 AM
TJSiegrist
Sep 10, 2015 09:29 AM
Slack
Sep 5, 2015 06:42 PM
chris424
Sep 2, 2015 10:18 AM
