RB RevI intake
Old Mar 3, 2007 | 07:22 PM
williamngRX8's Avatar
Flyboy
RB RevI intake
I just had my RB RevI intake installed and I completed it by following the instructions from RB but the problem now is the engine is kind of chocking at idle and the check engine light turns on.
did i miss something ? anyone had similiar problem before with this intake ?
Old Mar 3, 2007 | 07:25 PM
did you get the red cap on the manifold on? also check to make sure the maf is seated right and the connectors are tight..
Old Mar 3, 2007 | 07:32 PM
Flyboy
swoop..looks like that cud the culprit which i first thought wud not affect anything.
i cud not put the red cap back on when i first pulled the hose off. looks like i might have broken something. is there any other way to seal off the manifold ?
Old Mar 3, 2007 | 07:38 PM
you are going to have to be creative with that one.. rubber stopper maybe some jb weld..
Old Mar 3, 2007 | 11:46 PM
Flyboy
swoop, i have sealed off the manifold with a rubber and noticed engine chocking has stopped but check engine light still remains on
is there anyway to make the light go away ?
Old Mar 3, 2007 | 11:56 PM
it will take several drive cycles...
but. to help the sensors reset...
take off the neg bat cable.. switch the car key to on. then step on the brake...
reattatch the cable..
start car.. it will take a couple drives for the idle to settle down.. that is normal..
Old Mar 4, 2007 | 12:29 AM
Flyboy
huuurraaayyy i followed your above guidance and engine light finally went away
tks so much ...... i owe you
Sato Tatsuya
Oct 5, 2015 03:09 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
