Dual Sub DVC question --
Old Feb 26, 2007 | 06:58 PM
WikkedOne's Avatar
Deals on wheels
These are kinda newb questions but I'm about to build a new box and get a second DVC sub -- so I got some questions that I can't figure out what is the BEST way.
First in a box with 2 10's is it better to put a divider between them? or leave it out for more airspace. I was going to play it safe and put it in anyways.. but it may be better without it.. I thought i would ask
and if I'm going to hook up 2 DVC subs with 4 Ohms per coil- I want to have a 4 Ohm load on my amp
So would it make any difference if put both of the coils in series on each sub and then put the subs in parallel or the other way around?
So its basically a decision do I want my subs seeing an 8 ohm load or a 2..
What do you guys think?
Old Feb 26, 2007 | 07:15 PM
lurch519's Avatar
www.evoperform.com
some subs sound better with seperate enclosures, some subs it doesnt matter. though you should at least have some bracing internally so the box doesnt flex (much)
as to wiring the subs, it doesnt matter either way, as it is what the amp sees that counts. usually when doing the series parallel, we series the coils and parallel the subs. that way the power coming from the amp has 2 pathways, allowing more power to get to the subs, otherwise, you would only have one path to the sub, and would have to run bigger speaker wire to accomodate the power
Old Feb 26, 2007 | 08:37 PM
WikkedOne's Avatar
Deals on wheels
good points... thanx
Steve Dallas
RX-8 Racing
10
Oct 7, 2015 10:30 AM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Rupanrx
Sep 4, 2015 06:44 AM
