Important~ alignment/running tires backwards
OMGITM!
Got springs/shocks/18x9.5's in the past Monday.
Front Left
Camber: -.6
Caster: 7.2
Toe: .06
Front Right
Camber: -.5
Caster: 6.8
Toe: .11
Rear:
Total Toe: .38
Thrust Angle: .01
Rear Left
Camber: -2.2
Toe: .2
Rear Right
Camber: -2.0
Toe: .18
He then told me my car would be stable up to about 150 and that the tires would wear on the side. Said to rotate the front diag back and each of the back straight forward every 2 months or so to eliviate the uneven wear. This would mean tires would be facing the "wrong" direction.
My Question is - is running the tires backwards dangerous? He claims to have been doing this setup on his cars for years now and he's been in the game for ~35yrs. Said on F1/race tires the direction matters because of an overlap but on modern tires there was no big difference and he didn't notice any changes, even in the rain.
Opinions, comments, concerns?
If I should want/need to change I don't think there would be a problem, he accidently did the alignment with the 4 springs/shocks in the trunk. Place was cheap too, tires were $201 after tax/balancing (275/35/18 t1r's) and the total labor cost for install of springs/shocks/align was $140 (took em 5.5 hours, no lifts)
Front Left
Camber: -.6
Caster: 7.2
Toe: .06
Front Right
Camber: -.5
Caster: 6.8
Toe: .11
Rear:
Total Toe: .38
Thrust Angle: .01
Rear Left
Camber: -2.2
Toe: .2
Rear Right
Camber: -2.0
Toe: .18
I think your guy there is nuts.
Typically (not in all cases), directional tires are directional due to tread pattern design for water evacuation. Running directionals backwards is a bad idea if it is wet but shouldn't pose any danger if the roads are dry.
While experience is generally a good thing, people often use it as a reason to justify doing things a certain way that they have no logical way of explaining. Lots of experience doing something the wrong way has no worth, if not negative worth.
Originally Posted by TeamRX8
lol, how would you know
j/k
as stated above, directional only matters in wet conditions
j/kas stated above, directional only matters in wet conditions
yeah, guess what? Running treaded directional race tires backwards is actually common, as long as it was in the dry there wasn't any issue
besides, j/k is intraweb talk for "joke" so simmer down Francis because I was only kidding
Mostly though, quite a bit of communication is lost over the internet, especially so since I refuse to use the smilies.
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
GranTouTou
Sep 30, 2015 06:11 AM
