AF guage need some help!!!!
Old Feb 19, 2007 | 07:44 PM
rotaryfan04's Avatar
Revs to 9K!!!
Hey does any one kow what wire to hook up a AF guage to the o2 sensor on the 8 is blue white black? can any one help?
Old Feb 19, 2007 | 07:46 PM
mysql101's Avatar
you're trying to hook up an AF gauge to the car's stock o2 sensor?
Old Feb 19, 2007 | 07:53 PM
Revs to 9K!!!
yes but on the pcm side of the connector but there is 4 wires a blue white and 2 blacks. I know I need the 5 volt return but I dont have a volt meter to know what wire it is?
Old Feb 19, 2007 | 08:11 PM
Revs to 9K!!!
I know I need a wide band 02 before any one lets me know that. Im having a knock when I use my nitrous and Ive tryed everything I can think of I just wonder if Im running ritch or lean when I get the knock and this is a free test.
Old Feb 19, 2007 | 09:11 PM
you are running lean..
Old Feb 19, 2007 | 09:13 PM
Revs to 9K!!!
Im not sure thats why im trying the guage Ive read its knocks because its lean and ritch
Old Feb 19, 2007 | 09:14 PM
it knocks when it is lean.
Old Feb 19, 2007 | 09:20 PM
Revs to 9K!!!
Yes I know it will knock maybe knock is the wrong word I'm not sure if its Detonation; Knock; Ping; Pre-igintion. I just know it doesn't sound right and I would like to know what my mixture looks like when using the nitrous.
Old Feb 19, 2007 | 09:24 PM
all of those describe a lean condition..
Old Feb 19, 2007 | 09:28 PM
Revs to 9K!!!
any sugestions on what I can do to help with the lean conditions?
Old Feb 19, 2007 | 09:29 PM
Revs to 9K!!!
Ive tried 100 octane fuel and charles said maybe coils are bad, but he and I are both stumped.
Old Feb 19, 2007 | 09:32 PM
Brettus's Avatar
Boosted Kiwi
check out the nitrous thread .
Can't you get different jet sizes for fuel ?
Old Feb 19, 2007 | 09:42 PM
Revs to 9K!!!
Charles said not to mix and match jettings but I might, He said jets are only like 2 or 3 bucks each I was going to use my higher fuel jet for the 65 shot and use the 55 shot jets for nitrous.
Old Feb 19, 2007 | 09:43 PM
do you know for sure that your fuel side solonoid is working?
Old Feb 19, 2007 | 09:46 PM
Revs to 9K!!!
yeah I pulled the lines of the nozzle and sprayed into a bottle for fuel and nitrous, I also checked the side on the module marked fuel indeed had fuel coming out and same for the nitrous side.
Old Feb 19, 2007 | 09:48 PM
Revs to 9K!!!
I also had problems with intake backfires any Idea what caused that? Seems to have gone away on the 100 octane but at 7 bucks a gallon on a daily driver isnt going to go over well lol
Old Feb 19, 2007 | 09:59 PM
call me.
pm coming..
Old Feb 20, 2007 | 03:26 AM
MazdaManiac's Avatar
I feel a Darwin Award coming...
Old Feb 20, 2007 | 03:29 AM
that avatar is so less than you... barely hot..
Old Feb 20, 2007 | 11:50 AM
I just like its goofyness.
My avatars are like a good novel with highs and lows.
I love how people think octane is the answer to their car not running well.
The gasoline companies have done their job well.
Old Feb 20, 2007 | 06:24 PM
Revs to 9K!!!
Thanks for your input mazdamaniac but I didnt try high octane to make it run "better" I tried 100 octane because it is guaranteed not to have any ethnol in it and I live in kansas so ethanol concerned me with my nitrous not working well.
Old Feb 20, 2007 | 06:27 PM
Revs to 9K!!!
since 10% ethanol blends dont have to be posted and those blends only come in 91 92 93 octane rated gas I went to race fuel to eleminate me suspicsion of ethanol causing my pings knocks etc
Old Feb 20, 2007 | 06:34 PM
Revs to 9K!!!
Mazdamanic Charles H recomended I ask you if you knew what color the 5volt return signal wire is of the 02 sensor he said you might know if you do this would be helpfull information for me thanks
Old Feb 20, 2007 | 06:59 PM
You mean the rear O2 sensor signal wire?
What are you going to use that for? It won't return any useful information (not for tuning, at least) since its in the catalyst and its a narrow band.
Its not a "5v return wire", but the signal wire is yellow. Its pin 2Q on the PCM.
The red and white/red wires are the heater and the brown wire is power from the PCM.
The output is up to 1 volt - .55v is stoich. Anything that is not .55 is useless information.
Old Feb 20, 2007 | 09:33 PM
Revs to 9K!!!
I know its not a vary useful instrument for measuring the af ratio but no one cant figure out why it still knocks so I’m trying to find out if its truly a lean condition even if I cant find out just how lean it is or if its a bad zex module or failing coils? I believe there is a front 02 sensor not in the cat that I was planning to hook up to the colors you mention in the last post are on the pcm side of the connector any reason why you aren’t supposed to hook up on the 02 sensor side? Thanks for your help
Chris
