Question for those with aftermarket wheels....
Old Feb 17, 2007 | 02:24 AM
bch3779's Avatar
I am installing Axis Hiro rims on my 8. These wheels have a larger hub bore diamer than the stock wheels. Do I need to use hub centering rings? The Axis rims have the cone recess in the lug holes to help with centering but I have read it is not good enough. I also read on Tire Rack's site that if you do use a lug centric wheel (has cone recess): torque the lugs while the vehicle is on jackstands to help center the wheel without the weight of the car. So...........you guys with aftermarket rims: Did you use hub rings or say the hell with them. If I need hub rings does anyone know the stock hub bore?
Old Feb 17, 2007 | 11:23 AM
DarkBrew's Avatar
Extraordinary Engineering
Hubcenter Bore should be = 67.1
Bolt Pattern is = 5x114.3
http://www.1010tires.com/hubrings.asp
I use rings on my winters.
Old Feb 17, 2007 | 01:48 PM
RoXanneBlack8's Avatar
stop flooding ur engines
i use rings on my hiros as well
Old Feb 17, 2007 | 03:24 PM
bch3779's Avatar
What Lugs Did U Use? What Size?
Brokegang
Jan 3, 2016 12:45 PM
yankeepicker
Sep 11, 2015 05:42 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
