dont flame but what is the use of having a 6th gear
Old Feb 12, 2007 | 09:51 PM
sauceyI986's Avatar
ok I just had a coversation with my neighbor bout he having six gears on his vett and he can cruiz doin 110 at about 3 grand and my rx-8 sits around 7or8grand because to me the really int much differense between the 5th and the 6th gear. and yea I know a 05 zo6 and an RX-8 are different cars. if some can enlighten me please.
Old Feb 12, 2007 | 09:57 PM
mysql101's Avatar
1st - 3.760 * 4.444 = 16.7094
2nd - 2.269 * 4.444 = 10.0834
3rd - 1.651 * 4.444 = 7.3370
4th - 1.187 * 4.444 = 5.27503
5th - 1.000 * 4.444 = 4.44400
6th - 0.843 * 4.444 = 3.74629
It's an overdrive. Some people wish for it to go even further, but NA, you will not have much power to move if you needed to.
Are you sure you're doing 8,000 rpm in 6th?
Old Feb 12, 2007 | 10:02 PM
RazzyBRX-8's Avatar
Representin'!
I definitely don't think you're sitting at 8k RPMs in sixth gear.
RazzyBRX-8's Avatar
Representin'!
^^^definitely an overdrive as mysql101 said. Fuel efficiency on the highway so on and so forth.
Old Feb 12, 2007 | 10:08 PM
here's another one for you, my Z06 got 30 mpg cruising at 80 mph too
I use to takeoff in 2nd gear, shift to 4th, then 6th , gotta luv that torque
Old Feb 13, 2007 | 01:06 AM
spooledUP7's Avatar
I am one of those people. 6th kills me, and I keep grabbing for 7th. I have never been in a car where the OD rest at 4K at 75MPH. OD in my opinion is not a power gear, it is a cruise gear for steaming ahead at a constant speed. The argument for more power in an N/A doesn't make sense to me, because if you want to pass, down shift. There have been plenty of other cars out there with far less power that have a true OD.
It bothers me so much that I don't think I would have purchased the car had I been more aware of it. It's really my only complaint so far, but it does feel enormous at times.
Old Feb 13, 2007 | 01:48 AM
MazdaManiac's Avatar
8k in 6th is almost 140 MPH.
Old Feb 13, 2007 | 02:14 AM
rotarygod's Avatar
I'm usually in 6th gear by 35 mph!
Old Feb 13, 2007 | 02:58 AM
LionZoo's Avatar
road warrior
Your SA (or is that FB?) has a 6th gear?
Old Feb 13, 2007 | 04:08 AM
MegaLoL's Avatar
Same here
Old Feb 13, 2007 | 07:25 AM
mysql101's Avatar
It depends on how you look at it. The engine only spins at 1/3rd the transmission speed, so your engine is really 1,300 rpm at 4k.
If you're really that upset with it, I hear you can get a replacement final drive
Old Feb 13, 2007 | 07:47 AM
Imidazole's Avatar
I'd like to point out that even if my rpms are higher than most other sports cars in its final gear, going on the highway...
The RX-8 engine noise is still 10x quieter.
StealthTL's Avatar
Metatron
Cool What's the use.....
My question would be what is the point of 5th?
I accelerate at an on-ramp 1,2,3 then pop into 6th for "cruise" mode. If I need to overtake, 5th ain't gonna do it, it's 4th or even 3rd, since 5th is also useless for acceleration.....
S
Old Feb 13, 2007 | 08:13 AM
spooledUP7's Avatar
Actually the engine spins 1:1 with the transmission main shaft, but the rotors orbit at 1/3 the crank shaft rotation.
I think the real problem lies within the Diff. I think the perfect combination would be to install a 4.1:1 Diff with a shorter close ratio first gear so that you don't loose the ability to break the tires loose, yet you still lower your overal cruise RPMs.
Or, just get rid of the gears all together.
The real difference would be if the car came turbocharged, then nothing else would matter because who would care.
Old Feb 13, 2007 | 08:24 AM
sssuperman82's Avatar
i've had Returned
i think u put it in Reverse instead of 6th, cuz i once hit 8500rpm on 6th gear and it was FAST!....not safe but i did it at 3am on the middle of long *** highway with there is 18th wheelers only.
Old Feb 13, 2007 | 08:32 AM
Mazda-Rati's Avatar
the WANKEL made me do it
S
I agree %100. 5th is useless and I'm always going from 4th to 6th
Old Feb 13, 2007 | 09:45 AM
8is>enuff's Avatar
Bland
Originally Posted by sssuperman82
...i once hit 8500rpm on 6th gear and it was FAST!....
No you didn't.
Old Feb 13, 2007 | 09:59 AM
Feras's Avatar
the Doctor
8500 in 6th is north of 160mph...im calling shenanigans.
Old Feb 13, 2007 | 10:01 AM
Celronx's Avatar
Unregistered User
[QUOTE=sssuperman82]i once hit 8500rpm on 6th gear and it was FAST!QUOTE]
What is that, like 165-170 mph. Not without HEAVY MODIFICATIONS.
Butch Brown's Avatar
Tell your neighbor to try taking his Z06 to 8K !
Old Feb 13, 2007 | 10:27 AM
mysql101's Avatar
The rotors are the combustion chamber. Thus the engine spins at 1/3rd speed. The eccentric shaft doesn't count as an engine.
Old Feb 13, 2007 | 10:46 AM
rotarygod's Avatar
The only thing that counts is the eccentric shaft speed.
Old Feb 13, 2007 | 10:48 AM
rotarygod's Avatar
Nope, it's usually in 5th gear by that speed. Every once in a while I'll drive around in Brillo's car and I get up there pretty early. He always looks over at the tach when I do it!
Old Feb 13, 2007 | 11:30 AM
MrSuicideDoor's Avatar
clutch burner
lol, you said "shaft"
Old Feb 13, 2007 | 12:29 PM
8 Maniac's Avatar
Senior Member
dunno if this means anything but you gotta take into account the redline differences too... ZO6 redline is 7k rpm. So just to do ratios let's say 80 in 6th for rx8 is 4500 rpms (45 x 100) and the ZO6 is at 3000 rpms (30 x 100).
45/90 would be ratio of rpms to redline for the rx8
30/70 would be ratio of rpms to redline for the ZO6
difference between those is 1/14th... it's a noticeable difference, but not as much of a problem as you make it out to be (sorry if math was wrong or irrelevant)
