"kok kok..." sound when drive slow
Old Feb 4, 2007 | 05:25 AM
theboy's Avatar
RX8 newbie!
anyone in asia can help me with this.
i can hear some weird noise when the car drive slow and turning.
i did the TBS recall clean up the brake rotor surface and the rims back surface, but the noise is still there. anyone in asia had fix it?
Old Feb 4, 2007 | 05:46 AM
effie's Avatar
Nightmares be gone...!!!
spray WD40 into ur shock absorber dust cover (the 1 that protects the shaft)...... You will need to take off front wheels for this........ Sure kok kok sound hilang.......
Old Feb 4, 2007 | 05:51 AM
theboy's Avatar
RX8 newbie!
effie, i did spray some on the cover. will spray some into it later.
Old Feb 4, 2007 | 06:20 AM
theboy's Avatar
RX8 newbie!
effie, how long it will take effect? i just spray some on it and try driving it for a whiloe but its still there.
Old Feb 4, 2007 | 09:24 AM
effie's Avatar
Dude.... spray inside cover. no on cover...... Better insert the straw (comes with WD40 when u bought it) into nozzle of the WD40 can....... Spray WD40 inside towards the top portion of cover........ Noise shud dissapear after about 100-200meters of driving.
Old Feb 4, 2007 | 09:28 AM
effie's Avatar
I just did it "AGAIN" last week coz that annoying kok kok/ squeeking/ creeking sound came back again....... Now its all gone !!!! From what ive read in the Singapore/ US/ Aussie forums, a more lasting effect would be to take front absorbers out and grease those rubber parts throughly......... Its the rubber parts that's making all that noise and not the shocks & springs......
Old Feb 4, 2007 | 10:26 AM
theboy's Avatar
RX8 newbie!
AH! thanks!
Old Feb 4, 2007 | 11:30 PM
theboy's Avatar
RX8 newbie!
effie i tried but seem like not working. will it be on top where the anti roll bar is?
Old Feb 5, 2007 | 12:06 AM
koodoo's Avatar
hey i had the same problem too! last week went mazdamotor rectify & they change my engine mounting, but no use..theres noise again..
Old Feb 5, 2007 | 01:28 AM
theboy's Avatar
RX8 newbie!
its not the mounting, bad mounting will make the car vibrate when idle. hmm...
Old Feb 6, 2007 | 07:40 AM
theboy's Avatar
RX8 newbie!
hey guys if u happen have the " tok tok or kok kok" sound under 10km/h on the wheel. check your dics rotor. it might cause by uneven brake dics. i skim my dics and i fixed mine finally!
Old Feb 7, 2007 | 05:24 PM
theboy's Avatar
RX8 newbie!
the noise is back after a few drive. -_-'
Old Feb 9, 2007 | 06:09 AM
yowzer's Avatar
i don't have 'tok tok' noise, more like squeeking sound. Good thing the noise went away after I've changed my swaybars. Could have been something to do with the suspension?
Old Feb 9, 2007 | 07:03 AM
theboy's Avatar
RX8 newbie!
my mechanix tell me if the sound is after the change of swaybar then its the new bush. did u oil it when u install it?
Old Feb 9, 2007 | 10:15 AM
Genesis's Avatar
Driving Me Crazy
theboy...after 30k I still get the occasional low vibration "kok kok" sounds in my 6MT when I drive around bends or over bumps at low speed. In the past, I've swapped out my coilovers for HKS hypermax, swapped out my sways, braces, intake, exhaust....I've had everything checked for stability and it's fine. If you've taken you ride into a qualified mech to check and everything is fine, then don't worry bro, the 8 is a noisy machine, but that's why it's a sports car
Old Feb 10, 2007 | 07:11 PM
rav969's Avatar
hi Boy,
i have experience 2 type of kok ko sound before !
1. when at low speed, usually during turning ..or in a car park. Agent change my front absorder . Gone for a while but came back for 5000KM. sent it in again and they change the rubber "something" of the rear absorber . According to them, the alignment of the absorber was out ! .... i'm still waiting to see the result ,,,
2. If yours is a manual, u might want to check if it is due to the release clutch . put yr gear to netural and slowly release the clutch and hear for yrself. The lubricated my clutch and also mentioned that the sound might comes from the pump and ask me to monitor.... so far so good.
Hope this help.
Old Feb 12, 2007 | 07:55 AM
theboy's Avatar
RX8 newbie!
today after my girlfriend drive it for a 200km semi bumpy ride. and its raining, the sound is back and louder. this time i found where the sound come from, when i press on the brake at low speed, i hear the kok kok sound. when i release it, the sound is louder. so this mean its the brake! oh damn... i skim my rotor and the sound is still there, i think it might be the brake pad or something else. i am driving a auto rx8
GrAfiX
Aug 24, 2015 08:08 AM
Rx808BI
Aug 9, 2015 10:06 AM
arjunmshah
Aug 6, 2015 10:56 AM
dbarber
Jul 25, 2015 01:34 PM
