View Full Version : seriously- ideas to increase idle speed.
olddragger
02-02-2007, 11:34 AM
I know I have talked about this before. But really no answers were available at the time. Maybe there are now? The ideas i have heard are
1- drill small hole into the throttle body disc--how small? anyone done this?
2- install a mechanical hold spot on the accelerator pedal?
3- modify the neutal switch on the transmission?---How?
I REALLY would like to have an idle speed of 900-1K. engine is much smoother in that range. My current idle is ok at 800 or so but it does do a little search when you are stopping(drops to 700 or so for 1-2 secs)
answers/ideas anyone
olddragger
RX8Maine
02-02-2007, 12:31 PM
I completely agree with you. Car idles perfectly smoothly at 900 rpms, but once fully warmed up, it slows down and vibratres.
Drilling a hole in the throttle plate would almost certainly work, but could result in turbulent flow at partial throttle. At best it could sound terrible, and at worst, it could completely throw off the ECU's fuel calculations.
I don't think #2 is an option, at least not for me. I have tried to manually (pedally?) hold 900 rpms and it seems like the electronic throttle is either OFF, with an idle of 800, or when activated, opens enough to raise my rpm's to about 1200. I can't maintain anything less than that. Can you?
Altering the neutral switch would be great. My engine speed always stays right at 1000 rpms until the car comes to a complete stop, even when the clutch is in and I am coasting. There has to be a way to fool this into thinking that the car is still rolling.
Do those with standalone ECU's alter their idle speed?
rotarygod
02-02-2007, 12:48 PM
A small hole in the throttle plate does nothing noticable from a turbulent flow standpoint. It's like a small vacuum leak. My RX-7 has such a hole in it's throttleplate.
You need to take a valve and install it on a vacuum line that runs from before the throttle plate to after it. Adjust this valve's airflow. You can make a quick one fairly cheaply from hardware store plumbing parts to test how well it works and what the side effects are.
brillo
02-02-2007, 02:23 PM
This has been my biggest bitcha bout the car, although its been better as of late with the new engine mount braces.
I'm willing to even front the R&D costs to come up with a solution, as running a standalone seems to make the idle worse in general unless you go stupid rich with it.
The hole in the throttle plate is one idea, I tried briefly routing air around the Throttle plate per RG suggestion but the car didn't seem to like it. I may play with that somemore.
I like the neutral switch idea. I just don't have the electrical background to fashion up a switch or relay.
One other idea would be to fool the temp sensor at idle to run the car a little richer and high in rpms. maybe a rpm switch combined with a relay?
Brettus
02-02-2007, 02:37 PM
This whole idle thing has me intrigued . I think the 8's idle is very smooth & see nothing to improve on ...... what is the big deal with it ?
OD saying his idles at 800 does make me wonder if US spec cars are set a tad lower than JDM cars like mine at 830 - 840 (scanalyser reading) .
Mazda-Rati
02-02-2007, 02:51 PM
For the people with an aftermarket intake there is the unused VFAD nipple after the throttle plate.
A hole could be drilled in the resonator attached to the accordian tube to get the air before the throttle plate.
olddragger
02-02-2007, 08:28 PM
Ok--- now I have something else to tinker with:). Thanks for the idea RG. I have the ports available--I will have to find the type of valve to use--shouldnt be hard.
olddragger
swoope
02-03-2007, 03:26 AM
trick the ecu into thinking the car has not come to a complete stop... or wait for a flash tuner. i am suprised rb did not cover this with there flash..
beers :beer:
MazdaManiac
02-03-2007, 03:44 AM
Just about anything you do will be counteracted by the PCM eventually.
The target RPM is preset and it will do what ever it thinks is needed to keep the RPMs in the set range.
It will pull fuel, close the TB and even retard ignition timing.
I've tried a bypass valve (basically a controlled and metered vacuum leak), a clutch switch bypass, screwing with coolant temp sensor values, forcing airflow meter values up and down and air temp sensor modification.
Nothing creates a permanent change, except the coolant temp adjustment, but that interferes with the fan turn on and makes the idle mix a bit rich. It also ruins the throttle feel at low load and RPM.
Changing the target values in the EEPROM is the only viable option, other than going to a mechanical TB.
BTW - keeping the idle above 900 or so will dramatically raise the CAT temps.
TeamRX8
02-03-2007, 04:46 AM
mine doesn't need an idle speed increase, why does yours? :dunno:
but fwiw, the ability to change that preset is not too far away, it's just a piece of software code like all the rest of it ...
MazdaManiac
02-03-2007, 05:01 AM
Many 8's have a droopy idle. None of the flashes have addressed it.
Mine isn't particularly droopy, but it is an interesting problem to me.
The Cobb AccessPort is still a few months away, but for many people it will not be a viable option - especially those that aren't FI...
Charles R. Hill
02-03-2007, 09:17 AM
MM, since you mentioned the AccessPort, do you think that would be a mod that would go well with my desire to control my ignition timing for higher shots of nitrous? If so, I'll kepp an eye out for it and get it when it comes out. Thanks.
TeamRX8
02-03-2007, 01:40 PM
fwiw, it's probably more than a few months ... DNKV's 04' RX-8 idle seems fine to me too :dunno:
MazdaManiac
02-03-2007, 02:25 PM
I don't know that the AccessPort would help with the nitrous thing since there is no sensor in place on the Renesis to indicate the onset of the spray.
I think you would still want something external.
The AccessPort is physically done. It has been since November. The release is set for April.
Charles R. Hill
02-03-2007, 03:07 PM
MM, I hate to bother you with questions about Cobb stuff but their website is nil on the RX-8 AccessPort. I guess there are no external sensors on the AccessPort to allow trigger voltage(?). BTW, did you get my p.m. asking about help on a plug-and-play ignition controller module for precisely this purpose?
rotarygod
02-03-2007, 04:03 PM
EVERY RX-8 I've ever been in has a MUCH smoother idle than my RX-7 has and I've never wanted to change it.
brillo
02-03-2007, 05:21 PM
what about a temp fooler that is rpm dependant? Couldn't you build a device with a rpm switch that fools the temp sensor only below 1000 rpm? all you would need to do is get the temp sensor to register about 155 degrees which implies a idle value of about 850-900. Scotts cooling mod should still kick the fans on when needed, so you wouldn't overhead at idle.
just a a thought, but seems to cover the issues you mentioned.
MazdaManiac
02-04-2007, 01:23 AM
^^ Yep. That would do it.
Break out the soldering iron.
brillo
02-04-2007, 01:38 AM
cool. Do you have an RPM switch, I'm assuming you would know how to wire the switch to trigger the temp fake.
turbosa22c
02-04-2007, 01:48 AM
i would build a curcuit to manipilate the tps voltage.. what ever the stock tps voltage is, you need to raise just a little bit at idle. some sort of resistor or potentiameter. ecu sees a higher voltage and will control the throttle body to open. but i would be carefull, you dont want the voltage to get stuck at wot. but the question is does the stock ecu know what to do if it see a tps voltage that is too high. will it just circumvent the tps with a default value and render it useless, and then look at map sensor instead. then throws a code (tps voltage to high)
paulmasoner
02-04-2007, 02:01 AM
If you guys can better explain how all the parts work and fit together ie tps temp stuff etc. I can give you a basic mockup of a PCB that will give you the electric output you need where ever it is you need it. Should probably be able to give you part numbers from a cheap and reliable source for resistors, transformers, switches or whatever else you would need to solder something up.
then on second thought, most of you guys can prolly do this quicker and more efficiently than i could
edit: turbosa22c just edited his post with some interesting thoughts... altering voltage would be useless if it just circumvented and throws a CEL as the 'brain' learns
brillo
02-04-2007, 02:12 AM
well, the TPS is a pulse width modulation system, so I don't think a simple resistor will do the job, I had that thought, but MM pointed out that wouldn't work.
There is some margin for error with the stock PCM, as I read in a abreivated workshop manual I saw at 7stock. I think the idle rpm can be +/- 100 and still be ok, which means that if you could build a PWM controler it could work.
my idea about triping the temp sensor below a certain idle rpm seems like it would have the fewest issues since the car just thinks the engine needs to warm up more.
MazdaManiac
02-04-2007, 02:26 AM
Modifying the TPS output will only tell the PCM that you have pressed the gas or that the throttle is more open that it is and it will set up a feedback loop that will yield a new calibration for that sensor until it goes out of range.
What you want to do is have a circuit that reads the TPS output and set a binary "ON" when it sees idle (less than 1v on PCM terminal 1J).
Then, when the switch is set to "ON", and electronic switch across the CTS will increase its resistance to simulate something lower than 176° or so (which is a total resistance of about 300 ohms, which means adding about 60 ohms).
turbosa22c
02-04-2007, 04:35 AM
if you could just go to the source and modify the code itself. everyone is just waiting for the cobb access port. the question is will it allow us to do what we want or will it just be another tuning device that will keep us wanting more.
making the computer think its colder is going to make it run richer. it will think its still in warmup and closed loop may not come on.
i dont know, everycar is different, and the 8 is as different as it comes.
MazdaManiac
02-04-2007, 09:56 AM
making the computer think its colder is going to make it run richer. it will think its still in warmup and closed loop may not come on.We have already figured out what it will do at the desired temp reading.
everyone is just waiting for the cobb access port. the question is will it allow us to do what we want or will it just be another tuning device that will keep us wanting more.Yes. It allows you to completely change every single aspect of the OEM system.
I know it for a fact. I played with it myself in November.
Charles R. Hill
02-04-2007, 10:16 AM
All these mental gymnastics over a supposedly shaky idle issue? MM, you suppose Cobb could custom-build a version of the AccessPort that has that elusive "trigger circut" I am seeking?
MazdaManiac
02-04-2007, 10:27 AM
We're nothing if not obsessive.
The idle can be really disturbing. Its not like an RX-7 idle that is high and hunting.
Were talking the constant fear of stalling and bone-rattling when it goes below 700. (On a previous flash, I had seen it go below 500 and stay there!)
MM, you suppose Cobb could custom-build a version of the AccessPort that has that elusive "trigger circut" I am seeking?No. The AccessPort isn't a box, Its just a programming interface.
I think an MSD with a TPS trigger will essentially do what you want, but a box like the EMU will do it better.
Charles R. Hill
02-04-2007, 10:32 AM
Cool. Like you said, obsessive. For me, I am trying to keep the costs down to essentials-only. Would you be willing/able to design/build a box similar to the MSD stuff you're thinking of? It would be nice to do my own tuning with the Cobb and then have a trigger box to cut the ignition advance only when needed. My idle used to dip occasionally but I cleaned the MAF sensor and did that e-shaft reset that wasn't supposed to work. Now, my engine runs smooth, pulls hard like it used to, and I cannot wait to get the nitrous project back on-line. None of which has anything to do with this particular thread.......:)
BTW, do you and I ever sleep or log off this website?
MazdaManiac
02-04-2007, 10:36 AM
I'll sleep when I'm dead.
olddragger
02-04-2007, 10:50 AM
Lol --probably not:)
I just had an interesting result. I was doing regular mantainance--cleaning my maf or should i say "drowning it", cleaning my K&N out of the REVI etc. 1st thing I found was --dang the throttle boby was really dirty--really dirty behind the valve along with the upper manifools.:) Where the heck does that stuff come from anyway? I know I know. So I cleaned all that up--thank God for nitrile gloves. Then i saw that the revi screen--the transplanted stock one --actually had a little tear in it. I got a little nervous about that--didnt want a little piece of wire getting sucked into the engine-- so when i put it all back together--i left it out. Yes---no screens in my intake. And yes as you have probably guessed I now idle after stopping at about 1K initially for about 3-5 secs or so then she drops to about 850--even 875. This is after it has warmed up. Much improved. Before when stopping it was intitially dropping to about 700-750 then come up to about 800 or so. This is without any electrical loads on the car.
The no screens has not affected performance in any way that i can tell. Now whether this is a result of cleaning the TB, the maf, the filter or no screens--I dont know. But it sure danged helped. Thought I would past it on.
Why cant RB with it's flash mod address this issue? Would be an additional selling point for many.
olddragger
olddragger
MazdaManiac
02-04-2007, 10:59 AM
In most cases, pulling the screens yields a lower and/or erratic idle.
Plus, if merely changing the MAF output values produced a consistent result at idle, I would have don't it already.
I've tried tweaking the MAF values at idle one way or the other and it does not produce an elevated idle that is stable.
The TB gets gunked from blow-by drawn in through the OMP vent and the PCV vent.
Jax_RX8
02-04-2007, 11:53 AM
If you want a smoother idle, focus on what is causing the rough idle in the first place instead of trying to raise the idle speed to compensate.
Rough idle is almost universally caused by partially clogged injectors, fouling plugs, carbon buildup, or a combo of all three. Run some good fuel cleaners and feel the idle smooth out. If the plugs are beyond cleaning, then replace them.
Mine idles smooth as silk at 800rpm.
brillo
02-04-2007, 01:10 PM
Jax, while te above is largely true, many people have done that and still have an issue. The idle is so low and lean for emissions reasons that a change in temp, humidity, load from alternator etc...seems to cause it to shudder.
for those with FI, a higher idle would mean you could run the interceptor leaner at idle and not smell like a gas can.
MazdaManiac
02-04-2007, 01:41 PM
Mine idles smooth as silk at 800rpm.Sounds like an ad for Techron.
The actual cause for the rough idle in the Renesis is the thermal inefficiency of the motor itself, resulting in the need for overly rich mixtures for a stable idle. It is common to need over-rich A/F for a stable idle on motors with large breathing capabilities.
Mazda did an absolutely remarkable job in getting the Renesis to idle as smooth as it does at 14.7:1 or so. Remarkable.
Unfortunately, it only takes very small variances in the sensors and operating conditions to yield an instable idle.
TeamRX8
02-04-2007, 11:29 PM
you'll be lucky to see it by summer
ps: pay no attention to the flapping gums behind the curtain :hahano:
MazdaManiac
02-04-2007, 11:48 PM
Indeed, I've become accustomed to things being released way after people promise them, if at all.:shocking:
TeamRX8
02-04-2007, 11:59 PM
I didn't mean it in a negative way, due to their proven success they've had some unique opportunities made available to them that warrant being higher on the resources qeue
the RX-8 system is under heavy development, it will happen
I could be wrong on the summer release, but that's my expectation
MazdaManiac
02-05-2007, 12:05 AM
Well, the copy they had at SEMA was fully functional, so the main thing they had to complete was testing.
TeamRX8
02-05-2007, 12:09 AM
are you sure that wasn't for the Subaru rather than the RX-8?
MazdaManiac
02-05-2007, 12:15 AM
are you sure that wasn't for the Subaru rather than the RX-8?Heh. Uh, yeah. Absolutely sure.:spank:
The subaru doesn't have 3 injectors per rotor and trailing ignition.
Or an air pump.
Doesn't fire every rev, either.
swoope
02-05-2007, 12:28 AM
the templets i saw, that were not cobb... allowed for fun things like idle rpm and tire diamater... and a bunch of other stuff...
like killing a specific cel....
beers :beer:
TeamRX8
02-05-2007, 12:31 AM
my input wasn't generated at the Smoke En Mirrors Autoshow, so feel free to ignore the flapping gums that have been told otherwise ....
MazdaManiac
02-05-2007, 01:39 AM
my input wasn't generated at the Smoke En Mirrors AutoshowNeither was mine.
I went up to Ogden/SL in December to try to set up my pro-tuner/dealer account with Justin.
I'm already in a territory fight with Vivid, who wants the same.
I don't think Cobb's faking code.
The thing for the '8 is software (they call it the "AccessECU ProTuner"), not a hand-held like the unit for the Subies.
TeamRX8
02-05-2007, 02:31 AM
it will be, it's just not there yet :) but that's what I thought you were referring to when you said it was a done deal
errr, I meant behind the bag ... :p:
zoom44
02-05-2007, 02:51 AM
hmmm accessport ecu is "just" software?:) check your email jeff:)
TeamRX8
02-05-2007, 02:57 AM
no there will be hardware to go with it and it will marry itself to just one ECU (for individual purchasers), the delay will be the final development and production of the hardware
zoom44
02-05-2007, 03:03 AM
ahh ok you have your flasher box and you have your tuning software.
MazdaManiac
02-05-2007, 03:04 AM
They have had some supplier issues, but I figured that the "J's" had that sorted since they had so many units on hand already.
Yep. Dongle-ville
TeamRX8
02-05-2007, 03:17 AM
apparently the RX-8 is a different hardware setup, AP2.0 has been out quite a while for the Subies
MazdaManiac
02-05-2007, 03:21 AM
Sort of. The CAN implementation is different, even though the PCM is the same chipset.
brillo
02-05-2007, 09:10 AM
Here is to hoping they get it out soon.
In the mean time Jeff, get to soldering :)
