SUB and other quest
Old Feb 1, 2007 | 11:04 PM
xspecialkx's Avatar
SUB and other quest
hey guys, just starting to tune and have some newby questions...
i have the 10 spkr bose system and factory gps in an 04, what will need to be done to put subs in and not effect the gps. any feedbck is appreciated
Old Feb 2, 2007 | 05:45 AM
TurboEight's Avatar
Booost.
you should put the subs in like any other car, taking the lvl from ur left right speakers and wiring them up to an amp...it shouldn't affect how your GPS performs
Old Feb 3, 2007 | 10:03 AM
1145climber's Avatar
RX-8 Enthusiast
i dont have GPS, but i do have bose. one of your options would be identical to mine, and i think it's a pretty good/common way of wiring:
tap the rear 6x9 speakers' signals and run them to your amp. if your amp has an option for speaker-level inputs, then you can run the tapped signal directly. if your amp does not support speaker-level inputs, and instead needs a lower-level input, then run the tapped signal through a LOC (line output converter) and then into your amp, like i did.
some people advocate tapping the pre-amp signals, before they go into the bose factory amp, but i have no experience with this. next time, try searching for more info, there are hundreds of threads answering your question.
RX4life
Canada Forum
10
Mar 8, 2006 06:01 AM
Perth11
General Automotive
9
Jan 23, 2006 01:14 PM
Booster MPS
RX-8 Show and Shine
Feb 21, 2004 11:26 AM
colin204
Boowana's RX-8 Quest
Jul 23, 2003 11:55 AM
oilman
Feb 6, 2003 05:38 PM
