View Full Version : Pictures my Powdercoated Calipers
rx8guy86 01-31-2007, 01:06 PM I went ahead and put on the PowerSlot slotted rotors, Hawk brake pads, and powdercoated my calipers. Here are a few pics. Questions/Comments are welcome :)
Click to make larger :)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1795.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1795.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1793.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1793.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1788.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1788.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1787.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1787.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1784.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1784.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1780.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1780.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1779.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1779.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1778.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1778.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1775.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1775.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1774.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1774.jpg)
XDEEDUBBX 01-31-2007, 01:33 PM im not into red colored calipers (except BBK's) but atleast you did it the right way.
type59 01-31-2007, 02:18 PM me neither. not a fan of the faded reds but yours look clean. thumbs up for you! you have a shot with the whole car?
rx8guy86 01-31-2007, 07:52 PM Here are a couple that I have. I need to get some more sideshots.
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1890.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1890.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1870.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1870.jpg)
http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/th_134_1925.jpg (http://i41.photobucket.com/albums/e272/mazda3guy86/RX-8/brakes/134_1925.jpg)
snipaz2420 01-31-2007, 07:59 PM i think they look pretty good. i want to eventually do mine red also. probably not powercoated though. how long did you have to wait for them to be powdercoated?
shinka213 01-31-2007, 08:02 PM well done and very clean.....actually they are the best looking caliper i have seen...im not into red for my car with the black cherry but they look sweet with the white....
DarkBrew 01-31-2007, 08:03 PM What did it cost you for the powder coat? What sort of life expectancy will it give in this application.
rx8guy86 01-31-2007, 08:06 PM i think they look pretty good. i want to eventually do mine red also. probably not powercoated though. how long did you have to wait for them to be powdercoated?
To break down and sand blast all four calipers, powercoat them, install the pads and rotors, took us about 7hrs. The longest part is breaking the calipers down. You have to make sure every rubber seal is removed. There is a tiny O-ring seal in behind the cylinder in the front two calipers that was a pain to get out.
rx8guy86 01-31-2007, 08:08 PM What did it cost you for the powder coat? What sort of life expectancy will it give in this application.
The Caliper rebuild kit for the front and rear were about 40.00 per set (front/rear), powder was 20. The gun kit was about 200, but the cost of that was split two ways. We use the kit for alot of other things. As for the life of the powdercoat.... I use the most expensive powder. i tried to knock the color off by hitting metal against metal and it wouldnt come off. The manufacture said that the only way to remove the powder coat is to sandblast again. The calipers also clean VERY easy. Pretty much just spray them off.
Wilson 01-31-2007, 08:41 PM I think they look great. Nice and slick so they should clean up easily.
llzjayarzll 01-31-2007, 09:08 PM you think your rotor is gonna rust?
rx8guy86 01-31-2007, 09:11 PM you think your rotor is gonna rust?
I dont know. Its been about 3 months and they still look awesome!
prospectjtaz 04-05-2008, 12:26 PM Do you need to rebuild your caliper when powdercoating. Thanks.
kersh4w 04-05-2008, 02:04 PM looks very nice.
HiTMaNN 04-05-2008, 02:49 PM Could you post pictures of the rears?
WoodsOfGreenRx8 04-05-2008, 02:58 PM The Caliper rebuild kit for the front and rear were about 40.00 per set (front/rear), powder was 20. The gun kit was about 200, but the cost of that was split two ways. We use the kit for alot of other things. As for the life of the powdercoat.... I use the most expensive powder. i tried to knock the color off by hitting metal against metal and it wouldnt come off. The manufacture said that the only way to remove the powder coat is to sandblast again. The calipers also clean VERY easy. Pretty much just spray them off.
Where did you get the rebuild kit from?
altspace 04-05-2008, 07:32 PM Nice work!
nuke0907 04-05-2008, 07:38 PM old thread, but those look really good. how they holding up?
Nopstnz8 04-05-2008, 11:43 PM Check out my garage. I had mine powder coated and they are holding up great. It has been over a year and there isn't really any corrosion on the surface. Also, they stand out more than spray paint.
prospectjtaz 04-06-2008, 12:24 AM Did you rebuild your caliper too thou when you got them powdercoated?
Nopstnz8 04-06-2008, 12:26 AM Did you rebuild your caliper too thou when you got them powdercoated?
I don't think so. I bought my car used, and the guy who sold it to me owned a powder coating shop and had recently done it before I bought the car.
rx8spiritR 04-06-2008, 07:18 AM if you don't think so then it's most likely not powdercoated.
you can't powdercoat a caliper without taking everything apart, i mean pistons, seal, and all the hose well in this case no hose. they then will sand down the caliper and powdercoat it, after it's done, you'll have to rebuild the caliper that means put everything back together, be extra careful with the piston seal. That is a lot of work to do to a single piston rx8 caliper don't you think?
I was going to powder coat my claipers, however its too much time and effort to get it done. So i said eff it, i will stick with black paint.
But they look nice.
mbrule6465 04-06-2008, 09:35 AM Great results. Are those stock calipers? Nice looking rotors too. Thanks for sharing your photos.
Nopstnz8 04-06-2008, 11:51 AM if you don't think so then it's most likely not powdercoated.
Ok then I guess he did rebuilt the caliper because he did take them apart and then powdercoated them. Check my garage and you can see the pics.
prospectjtaz 04-07-2008, 08:42 PM My question is should you buy a rebuild kit, or just use the same pieces after powdercoating?
Gdawg522 05-03-2009, 04:24 PM Reviving an old thread but I'm looking to powder coat my calipers this summer and I was wandering where you get the rebuild kits for these. It would be nice if you could provide some sort of DIY for the disassembly of the calipers. I want to make sure that this is something that I will be able to do on my own. Thanks
