Setting up Konis and stiffer springs
Old Jan 30, 2007 | 12:43 PM
CosmosMpower's Avatar
1935 lbs. FTW!
I have a set of Koni SA's ready to go in the car this weekend and some Mazdaspeed springs in the mail. I wanted to get some input from some of you B stock and STU autocrossers on how you would adjust the shocks to be optimal. I know the MS springs are considerably stiffer than stock 280F/190R and want to adjust the Konis accordingly.
What do some of you guys run with the Konis and factory shocks as well as Konis and stiffer springs (Tein S tech etc). I'd like to get it close on the first shot as I understand it's a pain to remove and adjust the rears.
Car is 75% daily driven and autocrossed on most weekends. I can tolerate a stiffer ride as long as it's not overly harsh as a tradeoff for better handling at autocross. Something I noticed with the stock suspension is the rear gets a bit squirley trail braking and can sometimes oversteer a bit more than I like. Sway bars will be remain stock.
Old Jan 30, 2007 | 02:45 PM
I would set the rear at halfway to start (50%)
the front is easily adjustable so you can set it to whatever you can live with, probably will be at 75% or higher for autox
Old Jan 30, 2007 | 03:41 PM
1935 lbs. FTW!
Is that 1 turn up from full soft?
Old Jan 30, 2007 | 04:13 PM
CRX Millennium's Avatar
AA = Autox Anonymous
5.5 half-turns from end-to-end. If you listen to the experts, the adjustment on extreme ends are highly non-liner, so just do your best for ballpark middle ground.
Old Jan 30, 2007 | 08:54 PM
1935 lbs. FTW!
So I'm guessing about 3-3.5 turns is still tolerable but probably plenty stiff for autocross? I wish someone has some experience with the stiffer springs and konis so I have a baseline to set them
Old Jan 30, 2007 | 09:16 PM
olddragger's Avatar
i have the konis and the tein h springs along with the big rb bars. i dont autocross but i track. DPE(vendor on this forum) has some good info. I have found that on the rears 1/2 turn up from full soft works all around--track and street, while on the front I go 1/2 to 1 turn up from full soft. I do get a little full throttle exit understeer but on tracks i do (Roebling and Road Atlanta) being able to use the throttle to place the car is advantageous for me.
DPE is a good source--honest people and a real supporter
olddragger
Old Jan 30, 2007 | 09:24 PM
altiain's Avatar
Sparky!
I think you mean 5.0 half turns (2.5 total turns).
Old Jan 30, 2007 | 09:41 PM
That would be true, going with Koni literature. In reality, I counted 990dg, not 900dg from end-to-end. This is confirmed by others too.
Old Jan 30, 2007 | 10:25 PM
my (extensive) Koni experience is 2.75 total turns = 5.5 half turns
Old Jun 29, 2007 | 09:45 AM
LowCG's Avatar
Good info.
Any thoughts on good lowering springs to go with Koni sport shocks? Looked at Koni's site and see they make a kit with shocks and springs. I like the single adjustable, since I'm just starting to play with suspensions - not sure I would know what to do with the multi-adjustments.
Car use is limited weekend and road track DE. Seldom on long trips. I have a daily driver with comfortable ride.
Is there a noticeable change in handling with this setup (as opposed to stock or going with the Mazdaspeed shocks/springs with warranty)? I thought the car did pretty well at the track the way it was.
Car is stock 06 w/6 sp.
Also noted recommendations against going with a really stiff strut brace?
Open for comments -
thanks!
Old Jun 29, 2007 | 06:06 PM
1935 lbs. FTW!
Originally Posted by LowCG
Good info.
Open for comments -
thanks!
I would go with MS, they're the stiffest of most of the aftermarket springs and make my car transition very well. I have stock swaybars and the springs/konis take care of most of the body roll as well. I have had many people comment on how flat the car corners. I also heard Swift makes a pretty good product although I haven't read anyone with first hand experience.
It's hard to beat the Mazdaspeeds for the price especially if you're signed up for the motorsports program in which case I think they're $220 new. You can snag Konis for $550 shipped from a few vendors and online. I'm setup at 2.75 turns front and rear and it's tolerable on the street and fun at the autocross.
Old Jun 30, 2007 | 07:16 PM
olddragger's Avatar
suspenion setup is a highly personnel thing, according to driving style and tracks you are on. It also has to work together(and dont forget the tires/wheels you run). a couple of points I will throw in is
1- dont get the *** end to low--the chassis doesnt like it
2- strut bars dont matter over stock except one with a master brake cylinder support---you need that.
dont for get a professional alignment from a shop that knows performance.
olddragger
Old Jun 30, 2007 | 07:20 PM
olddragger's Avatar
oh by the way as you can see on my advitar---that turn is a tight left sweeper and I am running about 100mph ahead of that track prepared 5 series. I run 17's so i am a little lower. my suspenion is sport koni's(1 turn up from full soft up front and 1/2 turn up from full soft in the rear, tein H springs and rb bars and endlinks. I am running a 45 sidewall hoosiers.
if there was a way of enlarging that picture you can see a very prominent heat signature!
olddragger
Old Jul 1, 2007 | 11:14 AM
and shock adjuster access ...
Old Jul 3, 2007 | 07:22 AM
LowCG's Avatar
thanks, really appreciate the input.
quote: "2- strut bars dont matter over stock except one with a master brake cylinder support---you need that." and shock adjustment access.
who makes these?
Old Jul 3, 2007 | 11:04 AM
Michael's Avatar
Team, how are you liking the Progress bars with the konis?
Old Jul 3, 2007 | 01:39 PM
my Konis are quite different from these, but I'm big on the PT bars, highly recommended
Old Jul 3, 2007 | 02:08 PM
Michael's Avatar
Thanks.
I'm wavering between buying, installing, adapting, repeating...
or buying, buying, buying, buying (over time), installing all at once, adapting to a huge change instead of minute ones.
Old Jul 3, 2007 | 09:38 PM
olddragger's Avatar
mazdaspeed makes a good front strut and there are others that their names escape me at the moment.
od
Old Jul 4, 2007 | 09:42 AM
Mazdaspeed = JIC
RXFEVER
Aug 29, 2018 10:14 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
