No Boost Or Power
Old Jan 27, 2007 | 02:32 PM
jrtucker's Avatar
Unhappy No Boost Or Power
I have an 04 with the greddy turbo that is giving me ZERO boost and runs about like a stock 95 civic, it feels like it is bogging down just has NO power whatsoever at 5000 if anyone can give any advice I would greatly appreciate it, and i did change the plugs so that's not the solution
Old Jan 27, 2007 | 10:00 PM
wow,
with all that info this should be ez...... maybe find a local rotary shop????
what makes you think the plugs would be the solution?
Old Jan 27, 2007 | 10:14 PM
dshiznit1489's Avatar
Formerly Polak Graphics
add another turbo...duh
but seriously use the search tab. ull find plenty of threads that answer ur question
Old Jan 27, 2007 | 11:51 PM
chickenwafer's Avatar
Nope
Could be hundreds of problems. Need more info.
Old Jan 28, 2007 | 12:07 AM
jrtucker's Avatar
OK something i noticed is that my E-Manage's interaction light constantly stays on, it's not supposed to
Old Jan 30, 2007 | 08:49 PM
schnell8's Avatar
I just had a problem like that. My car wouldn't go above 4k rpm and boost would go to 0 psi and stop going up. Someone else on the forum mentioned catalytic converter so I took it off and checked it. Half of the cat was broken up inside and clogging the exhaust. It also destroyed the oxygen sensor.
Old Jan 30, 2007 | 08:54 PM
mysql101's Avatar
check your cat and coils too. we'll need more details though - any weird sounds? Does it only happen at 5k? Try swapping the trailing coils with leading and see if you get bogging issues when moving from a dead stop instead...
Old Jan 31, 2007 | 12:37 AM
does it start & idle ok?
Old Jan 31, 2007 | 02:11 AM
MazdaManiac's Avatar
I'm still waiting for that A/F reading, JR. Are you going to install a WBO2S or are you going to continue to abuse your engine?
Old Feb 1, 2007 | 12:00 AM
jrtucker's Avatar
No took it and dropped it off in a speed shop, it was strictly an emanage problem but thanks for the help MM
Old Feb 1, 2007 | 12:04 AM
great,
it would help us all to know where you are and the speed shop that helped you.
Old Feb 1, 2007 | 11:24 AM
jrtucker's Avatar
I'm in charlotte area, and i took it to a place called "project auto salon", and i highly recommend them.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
