Woww!!!! Wat A Rip Off!!
Old Jan 27, 2007 | 11:33 AM
peterisurhero's Avatar
peterisurhero
wow, you guys wont believe this. i've read in the thread that in order to changet the flywheel and clutch it would be around 3-4 hours long. so i called a mazda dealership so they can do it correctly without any mistakes. they quoted me a SEVEN hour job. so they wanted at least $800 for installation. i'm so amazed on how much they want to rip me off!!
Old Jan 27, 2007 | 12:03 PM
NoTears316's Avatar
Shock and Awe
Are these aftermarket parts? If so, why would you want the dealership to do the work? Of course it would be more expensive then a specialty shop.
Old Jan 27, 2007 | 12:52 PM
RotaryP7's Avatar
Seriously.. FML..
Just go to your local body shop. I'm sure they'll do the same type of work and probably better than your dealer. Oh, and cheaper of course..
Old Jan 27, 2007 | 01:36 PM
Silver_Surfer's Avatar
I4NI
The dealership is the most expersive place you can go. Do the math, I bet their labor rate is over $100.00 per hour. You could get it cheaper at "Jiffy lube" or "Wally world(Mart)" The question is you wanna go there?
Old Jan 27, 2007 | 01:56 PM
peter: Since you live in SoCal, you're in luck! Check out Rotary Reliabily& Racing in Santa Ana. They're a shop that's been around forever and they only work on rotories.
They'll probably do it for you MUCH cheaper.
Old Jan 27, 2007 | 02:51 PM
NoTears316's Avatar
Shock and Awe
hilarious! that was a good one!
Old Jan 27, 2007 | 03:25 PM
NgoRX8's Avatar
but it is true. of course
Old Jan 27, 2007 | 04:03 PM
PerformRX-8's Avatar
ROTARY-A-HOLIC
yeah never go to the dealer, because they'll always want to rip you off...... i usually go to the local meineke and i have a friend there who is a mech. He installed everything except the intake and the exhaust. and i would say roughly ive spent about 300 dollars in installation fees. so i would find a good local mechanic and build a good relationship with them so that they can help you out when it comes to installations.
Old Jan 27, 2007 | 06:08 PM
devildog1679's Avatar
My dealer did the MS CAI, MS exhaust and MS flywheel for $400
Old Jan 27, 2007 | 07:27 PM
Winning 8's Avatar
Hot Pit
if you think it is too much then find other shop, but make sure they have a 2-1/8" socket.
Old Jan 27, 2007 | 07:51 PM
to the people that say avoid the dealer. do you know what a ppf is and what the alignment specs are for it...
the price at a dealer is not set in stone..
food for thought.
Old Jan 27, 2007 | 08:38 PM
peterisurhero
will do!! thanks!!
Old Jan 27, 2007 | 08:51 PM
peterisurhero
for you guys who are wondering why i am taking my 8 to the dealership is because i know they will do a good job and hopefully not make any mistakes.
Old Jan 27, 2007 | 10:52 PM
9291150's Avatar
I have the MS flywheel. My "inside guy" tells me the book rate for removing tranny/clutch is 6 hrs, plus they'll add 30-45 minutes for the flywheel.
Old Jan 28, 2007 | 12:06 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
food for thought.
48.4-56.4mm from front tunnel member to PPF. But what order do you tighten the bolts at the rear of the PPF?
And 3-4 hours is cutting it close even for an experienced mazda tech that has done the job before. No way if they have to check the manual
Old Jan 28, 2007 | 05:54 PM
yes,
you and i know that, but i think most shops would not... that is why i think for this change a dealer, or a rotary shop that has done rx8s before...
a couple of years ago a big well known rotary shop missed this. it was a big problem. ugly thread...
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Ivan2terrible
Oct 24, 2015 05:21 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
Riot
Aug 27, 2015 04:01 PM
iSki123
Jul 27, 2015 12:41 PM
