View Full Version : More Heat Than Other Cars?
SaikoMelon 12-30-2006, 10:12 AM I did a rough search and couldn't find an answer so I thought I'd post. Forgive me if it's been posted before. (;_; )
My dad has been telling me that my 8 is generating much more heat than a normal car, in the sense that the boot, cabin and cup holder/compartments are warmer than his Ford. (cabin with air conditioning off in tropical weather)
Anyone find their 8 warmer than any other cars?
guy321 12-30-2006, 10:17 AM yes , duh
vectorwolf 12-30-2006, 10:24 AM Sure do. When it's warmed up, it's *warmed up*. Terriffic in chilly winter weather, but bothersome in the summer (to a point). Glad the AC works so well. :)
wicked1044 12-30-2006, 10:37 AM wait till the summer and you put something in your trunk that need to stsy cold! your F-ed!
nycgps 12-30-2006, 10:52 AM I did a rough search and couldn't find an answer so I thought I'd post. Forgive me if it's been posted before. (;_; )
Boot, because The engine is right next to it.
Cabin, Im not sure about where in cabin you talking about. Lets assume its the *middle* part. Especially Cup Holder. Thats because The Catalyst Converter is RIGHT UNDER the cup holder then the exhaust pipe goes all the way to the back.
Oh the trunk someone said? Thats because the WHOLE exhaust Thing is right under it. Dont even expect it to be cold (even winter, its NOT going to be that cold)
ITs great if you wanna keep the food warm (perhaps HOT)
Nothing really wrong with the car, thats what most sports car are like. (due to low clearance)
SaikoMelon 12-30-2006, 11:01 AM I see! Thank you! (@_@)
*learns*
Endor 12-30-2006, 11:25 AM Great in the winter though! Cranking the heat up to full and the fans to max feels like you could cook a turkey on the dashboard.
prescriptionmazda 12-30-2006, 06:28 PM Or better yet, put something in your trunk during winter that needs to be kept warm, works very well. :ylsuper:
mysql101 12-30-2006, 06:38 PM your engine/exhaust will run in the 1600 - 2000 degrees Fahrenheit range.
also look at where the engine is located - and where the exhaust is routed:
Spin9k 12-30-2006, 07:20 PM One can pretty nearly take care of this whole heat issue in doing a couple things:
1) make sure the dealer has done the necessary TSBs/recalls for gas tank heat shield/over cup holder heat shield (cup holder fix is actually a pretty weak fix on Mazda's part if you see what is done)
2) if you're the DIY type, installing a roll or two of aluminized foam heating duct sound deadener (USA home depot 10sq/ft/roll)/or similar dynamat type sheeting if you want to spend more. Remove the center console area and coat the tunnel with material, also remove the trunk liner and carpet and do the same there.
This helps alot up front, and as a side benefit in the rear, exhaust sound/ road-tire noise (esp if you have a cat-back) is significantly subdued.
Endor 12-30-2006, 07:51 PM your engine/exhaust will run in the 1600 - 2000 degrees Fahrenheit range.
An engine in the front of the car.... and an exhaust system which runs *underneath* the passenger section, and an exhaust at the back of the car! Brilliant! ;)
Phade2 12-30-2006, 08:23 PM It's a front-mid engine car....so it's one of the side effects of having the engine behind the front axle. Just like the porsche caymen's rear mid-engine placement, their cockpits are a lot warmer than the normal 911.
SaikoMelon 12-30-2006, 08:39 PM I see! /(@0@)\
this is all very informative! Thank you for the replies!
User24 12-30-2006, 09:53 PM The catalytic converter is about the hottest thing I've ever touched in my life.
Easy_E1 12-30-2006, 10:17 PM ^ooooooops
User24 12-30-2006, 10:35 PM I hope you don't mind the heat too much. It's a real minor issue. I'm thankful, because it could be worse, much worse. For example, we could have a shifter that looked like this:
http://img227.imageshack.us/img227/6710/IMG_0081ORIG.jpg
Terrible, humiliating.
Freddie 12-30-2006, 10:49 PM ^^^^^^^^^ W. T. F is that ? ? ? Whatever it is, it's just wrong.
8is>enuff 12-30-2006, 11:01 PM The catalytic converter is about the hottest thing I've ever touched in my life.
Haha.
This thread is funny and informative with not one "Search noob!" in sight. I have to try the DIY on this.
Winfree 12-30-2006, 11:16 PM Good news - it will keep your coffee warm
Bad new - you can't cook an MRE by throwing it under the hood
Good news - fresh bread in the trunk will come out still warm, also pies
Bad New - a bag of ice with a lobster in it, if placed in the trunk will become a bag of water with a lobster in it. Use ice chest if moving good wines or place on passenger seat
JeRKy 8 Owner 12-30-2006, 11:19 PM Sure do. When it's warmed up, it's *warmed up*. Terriffic in chilly winter weather, but bothersome in the summer (to a point). Glad the AC works so well. :)
Is that a joke?
The AC in this car "blows" especially down here where I live, in hell. Even the 4 cylinder econocars I've rented while my 8 is being serviced had better AC systems. If you live in a place where it's always at least 80 out and you're sweating when you get into your car, it takes forever for the damn air conditioning to actually feel cold. You have to set it to highest (4) and even then it's still weak compared to other vehicles. I've complained about it a bunch of times in both RX-8s I've owned. It's just shitty AC. Oh well.
Raptor75 12-30-2006, 11:24 PM The rotary's exhaust is few hundred degrees hotter then a piston engine. This is one reason for the poor fuel economy. More energy is lost to heat then in a piston engine.
nycgps 12-30-2006, 11:28 PM ^^^ Yup
Rotary Engine Produce and *trap* lots of heat. its Science and Nature that cannot be fix that easily.
Maybe one day they can come up with something like transfer the heat into other source of engery ? O_O
