sadly i have a newb question
Old Dec 28, 2006 | 10:46 AM
Feras's Avatar
the Doctor
I'm looking at a set of 18x8.5 wheels (maybe 18x9.5 i dunno)...how do i pick an offset? whats the widest tire i can put on a. the rim b. the car without any rubbing?
im thinking 255 40s 18s? or should i get 275s? or is that too wide for the front to fit and bad for handling as well?
Old Dec 28, 2006 | 11:34 AM
dmc27's Avatar
doin' the bull dance
f8cking noob - DIAF!!! - search and stuff, ect, ect.
Lol. I'll keep an eye on this one, as I'll need the answer come spring . . .
so how was NYC?
Old Dec 28, 2006 | 12:50 PM
shaunv74's Avatar
Power!!
Check out Rotorocks posts. I think he has 275's on his rear rims. He can probably enlighten you.
Old Dec 29, 2006 | 10:33 AM
KimiFelipe's Avatar
call conner at tirerack for advice.
Offset is how far away from the geometrical center of the rim your hub is. Modern cars have positive offsets, which pushes the hub toward the outer portion of the rim compared to where it would be in the center, i.e., zero offset.
Stock wheel offset is 50 afaik. Since you are going to a 1/2 inch, or about 12.5 mm wider wheel, I would _GUESS_ that you want a wheel with a slightly lower offset, for example, a 40 to 45 offset. If you use a wider wheel at the same offset you will risk having the inside tire sidewall rub on your suspension bits, and you dont want that. If the wheel is a 9.5 width you need a smaller offset.
You sound like you don't know what you're doing, so STOP. Get the exact specs on the wheel, then call Conner and ask for his help. He might even be able to offer you something you like better that fits your car.
tirerack.com
I'm just a satisfied TR customer. That is all
Old Dec 30, 2006 | 02:15 AM
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Dec 30, 2006 | 07:53 AM
jskup1's Avatar
The Chief
I got the Enkei RPF1's in one of the group buys here. They're 18 X 9.5 with a +50 offset. Although I got 255's on all fours, some people got 275's without any rubbing issues.
Old Jan 3, 2007 | 09:13 AM
Feras's Avatar
the Doctor
thanks for the info and jskup those are the wheels im considering, just havent decided between 8.5 and 9.5 yet.
Old Jan 3, 2007 | 10:16 AM
n00B
Old Jan 31, 2007 | 09:31 AM
Feras's Avatar
the Doctor
decided to go with RPF1s in 18x8.5" 40 offset wrapped in Eagle F1 245-40-18s.
Old Jan 31, 2007 | 11:24 AM
dmc27's Avatar
^ that post is useless w/o pics!!
Old Jan 31, 2007 | 11:48 AM
Feras's Avatar
the Doctor
pics are useless without the wheels here...they will be either on a boat or a plane soon and they wont go on my car till april seeing as how its snowing like every other day now.
Old Jan 31, 2007 | 12:07 PM
dmc27's Avatar
So you posted knowing full well we couldn't see it? Weak. lame.
j/k
Old Jan 31, 2007 | 12:31 PM
chickenwafer's Avatar
Nope
tease :D
j/k
jer2911
Sep 29, 2015 06:37 PM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Austin22
Sep 23, 2015 04:46 PM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
