Block-off Plate
Old Dec 25, 2006 | 06:05 PM
XCLUSIVSMITH's Avatar
BLACKICE
Block-off Plate
I am about to install my Greddy turbo-kit an in the box there is a intake manifold block off plate i was wondering if i can install the kit with out it? and if so (or not) what are the advantages or disadvantages of doing so??
Old Dec 25, 2006 | 06:22 PM
mysql101's Avatar
installing it will make tuning easier and you'll be able to use the emu out of the box.
If you don't install it, you'll need to do tuning before you get into boost or you'll run lean and maybe cause engine damage.
It's purpose is to block off 2 of the intake ports. Some view this as robbing you of power, but I don't think it's a big deal since the turbo can't feed the engine enough air at the upper rpms anyway...
it's a judgment call.
Old Dec 26, 2006 | 04:05 PM
SlideWayz's Avatar
RX-8 = Japanese MG
If GReddy were ever guilty of hillbilly engineering, this is it...putting in a blocking plate to restrict the flow so their puny 18g turbo doesn't get knackered as easily.
Just pathetic. Pathetic.
Old Dec 26, 2006 | 04:09 PM
ucleadguitar's Avatar
6 spd Newbie
Agreed! Does the MazSport turbo also block off the 2 ports?
Old Dec 26, 2006 | 04:12 PM
mysql101's Avatar
nope
Old Dec 26, 2006 | 04:16 PM
rotarygod's Avatar
It's a poor solution to an improvised system. It's like converting your engine to a 4 port from the auto. The Greddy turbo just can't take advantage of the extra airflow abilities of the aux ports.
Old Dec 26, 2006 | 04:19 PM
mysql101's Avatar
Right... it's not a great solution, but because of the flow on the greddy turbo itself, I don't think you're any worse than you would otherwise be with it off, since the turbo can't flow enough anyway.
PS: I can hold 10 psi to redline even in the warmer weather (85*) with the greddy turbo
Old Dec 26, 2006 | 04:35 PM
Charles R. Hill's Avatar
Owner of BHR
Where in the intake is the boost pressure measured in those kits?
Old Dec 26, 2006 | 04:40 PM
mysql101's Avatar
usually the VFAD throttle body nipple.
Old Dec 26, 2006 | 04:42 PM
Owner of BHR
Thx.
Old Dec 26, 2006 | 05:32 PM
mikeschaefer's Avatar
I wanna rock! Rock!
Don't the EMU and Int-x both prevent the opening of those aux ports though? So even if you don't install the plate the port valves won't open anyway. Just hypothesizing here... I still get lost with the amount of extra valves we have.
Old Dec 26, 2006 | 06:04 PM
MazdaManiac's Avatar
Actually, the way the Int-X gets around it is by keeping the ports open ALL of the time.
Fact is, in boost, it is the same either way - closed or open - with the relatively low flow needed for the sub-10 PSI that most people are running.
It is merely the "shock" of opening them that GReddy is eliminating by keeping them closed (and MazSport by keeping them open).
I find the idle suffers by keeping them open, so I open mine at 2800 RPM.
Old Dec 26, 2006 | 11:34 PM
SlideWayz's Avatar
RX-8 = Japanese MG
Yeah, I get a noticeable 'bump' between 4500-5000 rpms when the ports open. When I get my new turbo, I'll have the XEDE pop them open around 2500 RPM.
Old Dec 27, 2006 | 12:05 PM
BLACKICE
So I Can
I have the E-Manage Ultimate so if i don't use the block off plate your saying it won't make a world of diffrance anyway since the turbo doesn't make enough air flow to begin with right? and if i don't run the block off plate what would my AFR be like? one more thing does the E-Manage Ultimate controll the extra 2 ports or will my factory ECU still controll them??
Old Dec 27, 2006 | 12:12 PM
I wanna rock! Rock!
That's what I was thinking because I thought the Int-x kept them closed as well.
But now that I think about it, if you pressurize the intake system some of that air could escape past the aux port valves, hence the need for the block off plate.
Old Dec 27, 2006 | 12:19 PM
rotarygod's Avatar
It doesn't work like that. The pressure will equalize in the whole system. You don't need flow to have pressure.
Old Dec 27, 2006 | 12:21 PM
I wanna rock! Rock!
Then would air get by because of the increased flow?
Old Dec 27, 2006 | 12:42 PM
mysql101's Avatar
it doesn't flow enough to redline, but it will allow more air at 5600 rpm, and unless your fuel management has that under consideration you'll run lean... and due to the powerband, this is a critical spot, you don't want to detonate.
Old Dec 27, 2006 | 02:25 PM
BLACKICE
E-manage Ultimate
What if I use Methanol injection in conjunction with no block off plate will I still run lean after 5600 rpm with out changing my parameters on the E-manage Ultimate? Will 98 octane fuel reduce the effect of detonation?
Old Dec 27, 2006 | 02:34 PM
That is exactly what I didn't mean. How did you turn what I said into that?
What does meth injection or octane have to do with A/F? That is ignition timing.
Step away from the car...
Read this thread https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/so-you-wanna-tuner-100333/ .
Old Dec 27, 2006 | 05:12 PM
BLACKICE
thanks
Thanks for the insight. So i should just install the block off plate then, because i don' thave the software to tune the turbo. So for sure it will cause Detonation with out adjusting the fuel map? here is a link to my car so you guys can check it out http://www.cardomain.com/ride/2418023 thanks again for the advise.
Old Dec 27, 2006 | 06:07 PM
mysql101's Avatar
you can get the software from mohdparts.com - it's a free download.
Old Dec 27, 2006 | 09:24 PM
BLACKICE
The E-Manage is locked do you know the way to unlock it? and if it unlocks will it erase all the settings on the E-Mange?
Old Dec 27, 2006 | 09:28 PM
mysql101's Avatar
i posted the unlocked map in the emanage forums. it overwrites the existing map, but is the same map as what's currently locked on your unit.
Old Dec 27, 2006 | 10:28 PM
Could you possbly try the search button at least once in your online experience?
There is no need to re-invent the wheel and it is certainly bad form to ask us to do it for you.
