have a ? about midpipe install, not just another midpipe post
Old Dec 21, 2006 | 05:50 PM
ca18detsilvia's Avatar
ok so i got a used B&B midpipe, put it on and had an exhast leak between the midpipe and header so i got a new gasket and it fixed it. but i think i have a small leak where the midpipe connects to the exhaust. now there is no gasket but i guess some kind of swivel joint. what can i do to seal it correctly?? tomorrow i'm goin to put it up on a lift and try and move it around a bit to see if i can get a better seal, but i would like to know about anyone else experience with this. thanks alot.....by the way the car sounds freakin awsome, its alittle louder than i thought it would be paired with the mazdaspeed exhaust but it sounds amazing
Old Dec 21, 2006 | 05:55 PM
mikeschaefer's Avatar
I wanna rock! Rock!
There's a donut gasket between the midpipe and catback. If it's leaking you need a new one
Phantom Menace's Avatar
II SOCIETY
They sell exhaust tape/patches. It's like a strip of tape that you can use as a gasket between your pipe & muffler inlet.
Old Dec 21, 2006 | 08:17 PM
I wanna rock! Rock!
Exhaust tape is for repairing cracked mufflers/pipes.
Replace the donut gasket if it is damaged or missing. If there is a crack you'd be able to tell.
Old Dec 21, 2006 | 10:26 PM
yea, ill call mazda and see if they have any tomorrow, i may just try and get a paper gasket from pepboys or something like that and see if it will work. i also have my exhaust hung alittle higher because i have the carbing rear under brace and the exhaust hanger on the midpipe is hitting on something so i may just cut it off tomorrow, but im goin to play around with it tomorrow and see if i can work it out, thanks guys
Old Dec 22, 2006 | 07:49 AM
I wanna rock! Rock!
a paper gasket will not work, it's shaped for a donut gasket
good news is you can get donut gaskets from pep boys/advance/autozone
Old Dec 22, 2006 | 08:52 AM
dgrx8's Avatar
FN GR8
DUDE! please post a sound clip!!!
i also have a B&B midpipe & am undecided on what to pair it with.
thanks!
Old Dec 22, 2006 | 01:57 PM
thanks for the help guys, in my haste to put it in i didn't even put the rear gasket on, i didn't look at th stock pipe close enough at a glance it just looked like part of it. w/out that rear gasket the car sounded amazing but was way way too loud. with alittle bit of effort i installed the dounut gasket w/out having to take all apart again. Its now pretty quiet but i havent driven it too much since i fixed the leak, its still very streetable. The midpipe i got was one w/ the resonator and i was very impressed with the quality of it. i'll try and get a sound clip this weekend. i actually wouldnt mind haveing a slightly louder exhaust. after having the major exhaust leak which actualy sounded pretty good......it just seems quiet.
PTQLam
Aug 16, 2015 05:40 PM
MolecularConcept
Aug 5, 2015 04:43 PM
dbarber
Jul 25, 2015 01:34 PM
