volk ce28n
Old Dec 20, 2006 | 07:55 PM
staticlag's Avatar
The Professor
volk ce28n
whats the largest 17" ce28n that you can fit on the rx8 without rubbing? Would a 9" fit? a 10"?
Old Dec 20, 2006 | 08:43 PM
whoneedspistons's Avatar
well why would you put a 17 inch rim on a car that is stock 18 inches? seems a little wierd but to each there own
Old Dec 20, 2006 | 09:59 PM
unreal89's Avatar
I don't mind pistons
My guess would be:
Volk = light
17" = light
17" Volks = Super Light
Not everyone wants rims that are for bling. The fact he wants wide wheels indicates he wants performance.
Old Dec 20, 2006 | 11:59 PM
LionZoo's Avatar
road warrior
I agree. I for one absolutely hate upsizing on wheels as it adds weight, but at least I know the reason people do it. I can't really say I understand the viewpoint, but I know what it is at least.
By the way, how wide depends on the offset of the wheel and whether you wish to roll the fenders or not. It seems most people are able to take a 9.5" wide wheel with 45mm offset. Anymore and we start hearing rubbing.
Old Dec 21, 2006 | 01:44 AM
my 19 inch volks weigh less than my stock 18's..
Old Dec 21, 2006 | 12:49 PM
LionZoo's Avatar
road warrior
But your Volks in 17 or 18 inch would weigh less than your 19s.
Old Dec 21, 2006 | 02:20 PM
cavemancan's Avatar
The forgestar be with you
I dont know this for certain but the Enkie RPF1's 18x9.5 would probably weigh as much as the 17" volks and cost less. Approx. $308 per rim.
Old Dec 21, 2006 | 04:06 PM
LionZoo's Avatar
road warrior
CE28Ns are ridiculously light. In the 18x8 size they're 14.7 pounds. However, the thread starter would have better luck with weight savings if he went with the 18s as the 17 inch CE28Ns are only a few ounces lighter and the tire choices for 18 inches is actually slightly lighter and so would balance things out. However, if he's not looking to keep about the same rolling diameter, then 17s would be the way to go.
Old Dec 21, 2006 | 06:22 PM
Endless Rotaries's Avatar
Here you go:
17x9.5 +47 would be ideal and clear big brakes.
they also make a 10" +45 which is cutting it close, all comes down to tire size you choose. If you're interested we should be able to offer you a great deal. Let me know if you're interested.
Rishie
Old Dec 21, 2006 | 06:58 PM
gr8rx's Avatar
actually my 18 x 8.5 ce28's weigh in at a huge 13.7 lbs.......
Old Dec 21, 2006 | 07:22 PM
LionZoo's Avatar
road warrior
You showed me. Now if you don't mind, I'm going to go steal your CE28Ns.
Old Dec 24, 2006 | 03:50 AM
gr8rx's Avatar
Smile
good luck
Old Dec 24, 2006 | 08:45 AM
robrecht's Avatar
My CE28Ns weigh 6.5 lbs ... of course they're 14" on my 1993 Miata!
Old Dec 25, 2006 | 12:13 AM
gr8rx's Avatar
and you have me beat.
Old Dec 26, 2006 | 03:53 AM
tiltmode43's Avatar
OMGITM!
17's you ask? Cheaper tires, lighter weight, shorter gears w/right tires
If you're going with 17's staticlag make sure you have some sort of drop. The oe ride height looks a bit high with 17" rims
edit: Besides r compound tires, if you'll be putting the rims to race applications where you wish to run v710's count the 17's out, the diameter is actually larger than 18's
yurcivicsux
192
Sep 12, 2017 10:54 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
AussieGray
Jul 16, 2015 03:58 AM
rotarenvy
Jul 13, 2004 04:26 PM
