Remote and Ground BEST WAY??
Old Dec 19, 2006 | 04:33 PM
galaxygrey's Avatar
Cool Remote and Ground BEST WAY??
Dear all,
I was thinking ways to get the remote and ground cables back for the amplifier for new subwoofer, and i thought of the NAV system.
Can i use any of its cables for powering up the amplifier??
It has remote,ground,12v(+).
Regardz
Old Dec 19, 2006 | 04:40 PM
WikkedOne's Avatar
Deals on wheels
check the sticky thread at the top of this forum for info about the best places get and run wires. you should spend some time on the stickies of this forum before you decide to do any audio work.
Basically the best thing to do is ground it back at the battery and get your ground from your second cig lighter in the center console of the back seat.
Old Dec 19, 2006 | 05:39 PM
FastRX8's Avatar
IstanbulNotConstantinople
I grounded my amp in the trunk itself.
I was going to run a ground back to the battery, but decided to test some spots in the trunk first.
I got lucky.
I took a piece of 4awg wire and tested the resistance on the wire.
Then I used that wire to connect to the ground on the battery and test the resistance in the trunk at several spots.
I found an area that had almost no measurable resistance.
As WikkedOne mentioned, the cigarette lighter in the back is great for a remote lead.
Old Dec 20, 2006 | 05:20 PM
galaxygrey's Avatar
I didnt know that there is a second cig lighter :D
I will check on my car for it. What is the remote wire's color again?
Old Dec 20, 2006 | 08:03 PM
jstkilntim's Avatar
resU deretsigeR
Tap into the green wire.
Old Dec 20, 2006 | 08:46 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
I got lucky.
Is there any way you could post a pic of this "magical" area in the trunk that you used for grounding? Just curious...
Old Dec 21, 2006 | 10:35 AM
FastRX8's Avatar
I won't be able to post a pic for a few days.
It's not that magical though.
If you can point me to a picture of the trunk that shows the passenger side where the 4080 box goes.
I can highlight where I connected to ground wire to.
Of course the picture would have to have the carpet/covers removed.
Old Dec 21, 2006 | 02:52 PM
galaxygrey's Avatar
Nice one.
Can I also ask from where shall i take the sound for the amplifier?
My amp is a Monacor Carpower 2-way 550watt (200rms aprox i think). It has 2 rca inputs for the sound signal.
Old Dec 22, 2006 | 01:15 PM
All I could find on here was this...
Old Dec 22, 2006 | 02:12 PM
FastRX8's Avatar
OK - You're going to make me go out to my car and take a picture aren't you?
I'll try to get it done during lunch.
Old Dec 22, 2006 | 02:45 PM
FastRX8's Avatar
Ok, that wasn't so hard. I just had to get off my lazy butt.
To recap, here's a quote from forbidden's sticky on "What is proper ground", showing what I did to find this spot.
Originally Posted by forbidden
Disconnect the - battery terminal and disconnect the ground wire from you amp. If your dmm probes are not long enough, you will need to create a jumper extension out of some primary wire or whatever wire you have handy. Measure this wire for any resistance reading and subtract it from the total.
I took a piece of wire and measured the resistance. It read .4 ohms.
Then I started to test areas of the trunk getting over 1 ohm until I found this spot.
It measured .6 ohms, and sometimes .5 ohms.
Subtracting the resistance in the wire, that's .2 or .1 ohms.
Guess I just got lucky.
Here's a picture of the spot I used for a ground.
Rear passenger side behind the wheel well.
Old Dec 22, 2006 | 04:38 PM
galaxygrey's Avatar
So from where does your amplifiers get the sound signal ? How do you connect it to the oem player?
Old Dec 22, 2006 | 05:13 PM
FastRX8's Avatar
I'm not the right person to ask that. You'll need a line out converters (LOC).
I have an aftermarket headunit installed in the glovebox, so I just use rca plugs to the back of the unit.
I replaced all the speakers. I have a audio cable in the cup holder area which connects to my MP3 player, and I mostly play music from the mp3 player, and control the volume from there also.
You may want to check out this thread for info on the LOC.
https://www.rx8club.com/series-i-interior-audio-electronics-24/jedis-bose-stereo-upgrade-103771/
I you go w/ the LC6i, this thread has diagrams/instructions and pictures.
https://www.rx8club.com/series-i-interior-audio-electronics-24/sub-installation-lc6i-101128/
Old Dec 22, 2006 | 07:39 PM
Thanks a lot for taking the time to post that man. I have been having noise on my LCD screen since March whenever I use it to watch DVDs/tv with my DVD player/tv tuner. It's not that big of a deal but just something I always wanted to take care of. But I never wanted to run anything directly to the battery that anyone could see. Hopefully after I try using your idea and grounding to that bolt, it will decrease the noise.
Old Dec 22, 2006 | 10:29 PM
jstkilntim's Avatar
resU deretsigeR
I also used this spot and mine read about .01 ohms. The only problem I see is that there is only about a 4 gauge wire from the battery to the body. (without tracing the other 2, I assume 1 goes to the block and the other to the starter, but just a guess) This is OK for the system I have now, but when I install bigger amps, I will make a grounding kit and add a 2 gauge from the battery to the body and see how that works. If needed I will match my 2 gauge power wire all the way back to the battery.
Old Dec 23, 2006 | 07:54 PM
FastRX8's Avatar
It's actually just a hole. I sanded it down on both sides to expose the metal, and used a bolt to secure the wire.
Since doing that ground, I've adding a 4point grounding kit to the battery.
I didn't measure it, but I'm sure it improved some.
Good luck.
cliffkemp
Dec 24, 2024 10:48 AM
Learners_Permit
Sep 27, 2015 07:38 PM
gt4uk
Sep 20, 2015 07:19 PM
gt4uk
Sep 20, 2015 11:41 AM
