Haltech Interceptor?
Old Dec 14, 2006 | 09:44 PM
Bindon's Avatar
Fire-Spewing Maniac
Anyone looked into this?
http://www.haltech.com/interceptor.htm
RX8 is on the list of supported vehicles, and its ~ 850 US.
Anyone here running this?
Old Dec 14, 2006 | 10:39 PM
Ciao's Avatar
Yup .....Its a rebadged Exede
Been running it for over a year now ........bewdiful
Old Dec 15, 2006 | 12:04 AM
Never heard of it.
Old Dec 15, 2006 | 12:18 AM
BigOLundh's Avatar
#1 Legend
hmmm - sounds like it'll work similar to the interceptor-x but with haltech software instead of microtech.
I knew haltech was working on this for a while, but never knew it was out. The "universal wiring" harness sounds scary though. Does that mean its similar to older Engine Management Systesms that require you to splice the OEM wires?
More information is needed on this ASAP.
-hS
Old Dec 15, 2006 | 06:11 AM
Bindon's Avatar
Fire-Spewing Maniac
Hmm, very interesting.
Haltech makes some really sweet stuff, so Ill try to find out if theres a plug and play loom.
Old Dec 15, 2006 | 04:05 PM
RX8PR's Avatar
rgonza is using a haltech but stand alone in his 3 rotor Rx-8
and the Blue Rx-8 with Renesis engine and custom turbo is also using a Haltech also stand alone. I'm still using microtech LT12S on mine but considering
to moving to a haltech...............................
Manuel
Old Dec 15, 2006 | 04:23 PM
for NA you're better off waiting for the Cobb AccessPORT, no word yet if it will be setup to support FI
Old Dec 15, 2006 | 04:31 PM
Red Devil's Avatar
From Trey:
The Mass Air Flow sensor is used to help determine the actual Engine Load currently being experienced. All the primary engine calibration tables, like fuel and timing, are referenced RPM vs Engine Load. So, when tuning for a FI application you simply take into consideration the fact that you'll be generating more engine load than you'd otherwise see with a NA application.
To do this, we simply rescale the Engine Load references to the fuel, ignition, and other tables so we properly address the needs at these higher Engine Load values. Ultimately, this means you can not only tune and optimize how the engine runs off boost but also as it comes onto boost and when its maintaining full boost.
Other systems that use just a MAP sensor without a MAF are making "assumptions" as to how much air is coming into the engine based on a pre-programmed VE table. Honestly, I'm part of the camp that prefers a MAF system if I have to pick MAP vs MAF. Some cars have both, others like the RX-8, EVO, and 350Z have only a MAF sensor. I think tuning with a MAF system is consistent and perhaps a little easier. I'm happy to discuss this more in-depth if you still have questions as to why.
I took it based on this that handling boost was an absolute certainty with the Accessport/Street Tuner software.
Old Apr 14, 2007 | 08:27 AM
Spin9k's Avatar
Momentum Keeps Me Going
Bump? has anyone more experience with the Haltech Interceptor? Bindon did you get one? Any other thoughts about it?
This optional item looks very nice for tuning in real time
Trim Module
The Trim control gives the operator a remote access control for finely adjusting either turbo boost, fuel or ignition trim. Can be used with or without a PC connected to the ECU. Ideal for tuning whilst on the dynamometer. It is suitable for use with all current model ECU’s and supports:
+/- 12.5% fuel mixture
+/- 50% fuel mixture
+/- 10 degrees ignition timing
+/- 10 degrees trailing split (Rotary engines only)
0 – 100% turbo boost control
Old Apr 15, 2007 | 07:24 AM
Bindon's Avatar
Fire-Spewing Maniac
i havent got one yet, but haltech sent me the wiring diagrams for the 8, and its super easy to install. I think its just a matter or someone taking the dive and trying it...Its essentially a E6X, which is a good system, so I have no doubt it will work nicely, someone just has to be the first to try it
Old Apr 15, 2007 | 08:13 AM
Spin9k's Avatar
You're the guys with the SC, so I'd say you've the best most likely ones to give it a shot. If it worked well for boosting the 8, you'd have a nice engine mgmt system to offer in your kit.
Old Apr 15, 2007 | 09:38 AM
GAMBEAN's Avatar
bi polar rotor loner
I'm building a custom turbo set up for my 8. I had my experiences w/ the old school haltech e6k and then changed to a microtech lt10s on my fc. i liked them both in different ways.
I will try out the interceptor when the time comes.
Old Apr 15, 2007 | 01:15 PM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
The price is more like $900+ USD.
Don't forget you will also pay an exchange fee on top of the actual conversion amount.
Old Apr 16, 2007 | 07:50 AM
BigOLundh's Avatar
#1 Legend
so the haltech doesnt tune based on MAP and MAF - just MAF?
hmm - i dont like the sound of that.
-hS
Old Apr 16, 2007 | 05:52 PM
Ciao's Avatar
Not true .It comes with a MAP sensor and it does some MAF trickery .
I have used this solution for years .I have since moved over to Microtech . My power output has doubled , sorry trippled since then ,
Ciao
Dave
Old Apr 16, 2007 | 06:07 PM
MazdaManiac's Avatar
So, you are up to 510 WHP now?
Sorry dave, I couldn't resist!
The Microtech is sold as a P-n-P by MazSport as the Int-X.
Haltech is/was the state of the art for a long time.
I haven't looked at this unit since it first went into development, but it is likely a better solution than the Microtech since it has more granularity in the software and more configuration options.
Old Apr 16, 2007 | 08:00 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
It says its a "piggyback" but does it take full control of the fuel and ignition like the Int-X?
Old Apr 16, 2007 | 08:46 PM
rgonza's Avatar
Rob gonzalez
Cool
DIFERENCE BETWEEN HALTECH E 11V2 AND MICROTECHFuel & Timing resolution Haltech 32 bits versus microtech 16 bits.
Idle motor control or iac halteck takes control of all. Microtech only two wire Iac.
Haltech with haltech heuc module generatas more spark power at spark plug than microtech.
A lot of configurable I/O Analog and digital channel microtech just 2 chanel and are digital.
you can use from 1 cylinder up to 12 cylinders withuot to sent to factory for reconfiguration.
BTW i have already installed on my car and work like factory car specialy in idles with a/c.
Old Apr 16, 2007 | 09:11 PM
Spin9k's Avatar
The manual makes for a good introduction.
http://www.haltech.com/downloads/Int...r%20Manual.pdf
Old Apr 17, 2007 | 02:34 AM
Brettus's Avatar
Boosted Kiwi
reading the manual - no it doesn't . Seems to work the same way mine (powermod) does in that it just modifies the timimg & fuel by a % .
Works really well for N/A . Can't comment on turbo .
Old Apr 17, 2007 | 02:38 AM
No. It is basically a fancy S-AFC.
Old Apr 17, 2007 | 02:52 AM
Brettus's Avatar
Boosted Kiwi
Not sure if you are saying I'm wrong MM but here is what it says the manual .
Mine works a bit different on the Timing but the same way with the fuel from what I see here .
Old Apr 17, 2007 | 03:01 AM
No, I'm saying you are right. It is just a MAF modifier. It doesn't "intercept" the injectors the way the Int-X does, or even the EMU, for that matter.
Old Apr 17, 2007 | 03:04 AM
paulmasoner's Avatar
Asshole for hire
this thing sounds nice, or at least worth a try to me, although i dont understand jack about this stuff. sounds like the haltech just uses a lot of tomfoolery to get results you want
Old Apr 17, 2007 | 03:11 AM
Brettus's Avatar
Boosted Kiwi
Actually now I have re-read it I can see what you are saying MM & no mine does not work the same way - OOPS .
Is this the same way the old (failed) E-manage used to work ?
