Help - need tool to remove fuel ring cover!
Old Dec 12, 2006 | 01:00 PM
demon's Avatar
Mazda wants ~$200 and approx 3-4 weeks to get this tool which removes the ring housing the fuel pump. rgonza had suggested that Snap-On makes a tool that will do the job but I couldn't find anything that actually worked (already tried the Ford fuel filter wrench).
Does anyone have any ideas or know where I can get something that will work?
Old Dec 12, 2006 | 01:05 PM
MazsportScott's Avatar
Mazsport.net
pm sent
Old Dec 12, 2006 | 01:13 PM
expo1's Avatar
He's as bad as Can
I am 19,000 miles away from mazda's recommended replacement of the fuel pump. Please keep us posted on your DIY fuel pump change.
Old Dec 13, 2006 | 11:45 AM
howardteets's Avatar
Use a rubber mallet and a wide bladed flat head screwdriver.
Old Dec 13, 2006 | 11:58 AM
guitarjunkie28's Avatar
port hacker
+1
Old Dec 13, 2006 | 04:54 PM
demon's Avatar
Wow, does that really work without widespread destruction?
Old Dec 13, 2006 | 05:31 PM
m4f1050's Avatar
I figured it would be better to break that ring and buy a new one when ready to put back together.... But is that ring a buyable part from mazda? Any ideas?
Old Dec 13, 2006 | 06:42 PM
it better be made from something other than carbon-based steel (aluminum, stainless, brass, etc.) because sparks and gasoline vapors do not go well together
Old Dec 13, 2006 | 07:19 PM
I've never seen a fire started this way but you want be completely paranoid about it use a brass screwdriver.
Taking the ring off I wouldn't be too worried anyway. If you have any fuel on the outside of your tank before removing the fuel pump module you have other issues that need to be addressed first.
Angle the screw driver so that it is almost sideways so that when you hit it will give it a turning motion. Well sideways as much as possible anyways, it can be difficult inside the access hole. It a lot easier if the tank is sitting on the floor.
Old Dec 13, 2006 | 07:23 PM
mikeschaefer's Avatar
I wanna rock! Rock!
or try wrapping it in electrical tape, that's what I do when I pry interior plastics
Old Dec 13, 2006 | 08:36 PM
I went to the dealer with donuts and coffee.....and they let me borrow it for a few minutes...and did my mods in the parking lot.......
Old Dec 13, 2006 | 08:53 PM
demon's Avatar
I'll be doing it on the car, I guess I'll give it a shot and see what happens...the ring is cheap anyway!
Old Dec 14, 2006 | 12:26 PM
It's SOP when dealing with flammable materials. Like with any safety procedure, it always seems like a waste of time/effort until something goes terribly wrong ...
Old Dec 14, 2006 | 03:34 PM
Point taken. Kind of like a "famous last words" scenario.
Old Dec 28, 2006 | 04:44 PM
demon's Avatar
Well this didn't work at all; I ended up destroying about 3 of the tabs trying to get some sort of rotation on the thing. I guess I'll need to order the special tool!
EDIT: I ordered a couple of replacement rings through Mazdaspeed @ $24/pc. I figure I'll just break this one off (or dremel it out or something) and replace with the new one. I can order 8 rings for the price of the tool!
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Warrior777
Jun 24, 2019 04:47 PM
ShadowGryphon
Aug 23, 2015 02:46 PM
motohegg
Aug 23, 2015 08:14 AM
dbarber
Jul 25, 2015 01:34 PM
