19x10.5?!?!?
Old Nov 30, 2006 | 04:46 PM
ac3mastuh's Avatar
Got Ings?
19x10.5?!?!?
Hey guys, I'm just about to order my volk GT-S wheels and I wanted to order 19x8.5 with a 235/35 and a rear 19x9.5 275/30.
My question is if I could fit the 275 tire on the 10.5" rim since the rim is still narrower than the tire, just barely.... I was going to order the rear in a 37 offset so its both available in the 9.5 and 10.5 so either way the tire is going to rub.
Some tire companies say you can fit the 275 tire on the 10.5 but these were going to be wrapped in T1R's from Toyo and their site only says you can fit a 275 on a max 10 inch rim.
I think that the 4.2" lip rear would look really good but any suggestions would be greatly appreciated.
Old Nov 30, 2006 | 05:01 PM
LionZoo's Avatar
road warrior
Why exactly are you putting on tires that rub? I can't see the point in that, especially since it's a safety issue.
Old Nov 30, 2006 | 05:11 PM
your cutting it close even with a +37, you will also have to cut away every mm of inner fender and also run a -2 or a -3 of camber in the rear. Also say good bye to your tires!
Old Nov 30, 2006 | 06:57 PM
ac3mastuh's Avatar
Got Ings?
well, i figured that alot of people here have run a 275 rear tire and it does slightly rub. I was not going to lower the car for a while but I was going to roll the fenders as far as they would go. The only part im concerned about is the fact that the 275 tire is meant for a 9.5 rim. Would it look really stupid or cool on a 10.5 rim? I know that the 37 offset is a bit aggressive for the rear but i've seen other guys run that or a bit lower too.
Old Nov 30, 2006 | 08:38 PM
RA-Eight's Avatar
Scuderia
I think the 275 on 10.5 will make it look streeeetched.
Old Nov 30, 2006 | 11:12 PM
ac3mastuh's Avatar
Got Ings?
i kinda thought it would but how bad is kinda what I want to know. I think the rim would look like its popping out of the tire
Old Dec 1, 2006 | 12:48 PM
RA-Eight's Avatar
Scuderia
Well technically, you can fit 10.5 on 275/30. They're rated for widths 9.5-11".
Old Dec 1, 2006 | 11:26 PM
Stick with the 9.5 or 10 " wheel and get as close to 45mm as you can.
9.5x42mm
ableobject
Aug 3, 2015 01:26 PM
RAVSPEC
Vendor Classifieds
May 14, 2014 12:42 AM
Nikebot23
Feb 25, 2013 07:09 PM
RAVSPEC
Vendor Classifieds
Mar 23, 2012 11:26 PM
aliveoutofhabit
Nov 19, 2008 05:53 PM
