Any Issue with Tien S-Tech on Shinka Stock Struts?
Old Nov 29, 2006 | 09:15 PM
time4akshun's Avatar
Shink'd Out for 2006
Hey All,
So I am throwing my new wheels on this weekend and figured I'd also install my S-Techs that have been sitting around for a while waiting for me to get them on.
Been researching coil-overs, adjustable struts, yadda yadda yadda, but don't wanna make the investment now. The springs cost me $130 new and I'm psyched about the drop to my Shink.
I assume the stock struts can handle the lowering spring with no issue? Been a while since I did this to a car (1998 Eclipse Spyder was the last so bear with me)
Time
Old Nov 30, 2006 | 08:59 PM
redcivic's Avatar
Guns, God, and Country
The stock struts should handle them just fine as long as you are not a track addict. The stockers are Tokicos.
Old Nov 30, 2006 | 09:39 PM
Definitely not a track guy. More of a street cruiser/racer.
Thanks for the definitive and confident answer. I had heard the struts were a good aftermarket name brand but forgot which one! Tokico it is!
Time
Old Dec 1, 2006 | 08:01 AM
CosmosMpower's Avatar
1935 lbs. FTW!
They should be fine for a while, I guess 10K miles but eventually the harsher spring rates and lower ride will blow the shocks out.
Redcivic, there are not even struts on this car. All 4 corners are shocks.
Old Dec 1, 2006 | 09:18 AM
maxxdamigz's Avatar
Baro Rex
Isn't a strut merely a shock absorber mounted inside the coil spring?
Old Dec 1, 2006 | 09:33 AM
1935 lbs. FTW!
No, a shock mounted inside a coil spring is a coilover. A strut has a perch for the spring to sit on.
Old Dec 1, 2006 | 09:42 AM
Jax_RX8's Avatar
Got Another Rotary
Once installed, let us know how you like the S-Techs. I am thinking of adding these exact same springs for the drop and handling. I was also wondering how they feel with the larger Shinka shocks.
Old Dec 1, 2006 | 09:54 AM
dmp's Avatar
dmp
RX8 and a Truk....
Are Shinka struts different than normal RX8 struts?
Old Dec 1, 2006 | 11:46 AM
Jax_RX8's Avatar
Got Another Rotary
Yes.
Most of the Shinka package is cosmetic, but it does have larger/stiffer shocks and some chassis stiffness enhancements (urethane foam injected cross members if I recall correctly) to aid handling.
Old Dec 1, 2006 | 03:45 PM
CURED RX8's Avatar
I like the color
I believe the shinka shocks are 14mm (up from 12mm) and so they would be a "softer" shock, right? Maybe someone with more suspension knowledge, can elaborate on how that works.
Old Dec 1, 2006 | 04:12 PM
Red Devil's Avatar
From what I've seen, H Techs are ok with oem dampers and S techs are a bit too stiff. Curious to see feedback of them on the Shinka dampers, as personally, I think that is more of a gimmick than anything else.
Old Dec 8, 2007 | 10:04 PM
CURED RX8's Avatar
I like the color
Sorry to bring this thread back from the dead, but did any of you guys (or anyone for that matter) put Tein S or Tein H Springs on their upgraded 14mm OEM Shinka shocks?
How did it work out?
I am ready to lower my 2006 Shinka and am going back and forth between the Tein S or Tein H. But I always wondered if the upgraded Shinka shocks were "upgraded" enough as to handle the stiffer springs and/or keep the daily drive comfortable.
Old Dec 8, 2007 | 10:07 PM
shinka213's Avatar
Pettit fangurl <3
ive got the tein S techs on my 05 shinka...no problems at all...
lowers it just the right amount..
im very happy with them..
Old Dec 8, 2007 | 10:19 PM
CURED RX8's Avatar
I like the color
shinka213,
Are you still on the OEM Shocks? For how long now (I'm curious how long they'll hold up under the stress)?
And how is your ride on the daily commute?
Old Dec 9, 2007 | 08:07 AM
shinka213's Avatar
Pettit fangurl <3
still on the oem shocks...no plans on changing them...
ride is just a little stiffer...no problems with commute...
and im an ole lady ...
WingleBeast
22
May 23, 2016 09:22 PM
Kahl
Aug 20, 2015 11:49 PM
Mr.Durden
Aug 12, 2015 02:21 PM
Jazzmeson
Jul 31, 2015 01:48 AM
dbarber
Jul 25, 2015 01:34 PM
