Can someone of you guys make some suggustions
Old Nov 25, 2006 | 11:03 PM
matt5462's Avatar
I am going to buy a new set of rims in the next few weeks, I want to stay with 18's but would like a few suggestions so I can begin/finish my research. I would like the lightest or light weight wheels. I have mazda speed ways, tein flex*, MS front and rear strut suports and a few other engine/body peices. cost isn't a make or break deal..............It's what looks good and what will help with the unsprung weight. I am willing to give some or each factor for the best/better setups in 18inch trim.
1.Brand
2.Model
3.size/width
4.tire size
Thanks inadvance.
Old Nov 25, 2006 | 11:05 PM
zephir's Avatar
It be a good idea to give a price range your looking at.
Old Nov 25, 2006 | 11:24 PM
Phantom Menace's Avatar
II SOCIETY
If you drastically deviate from the total size of the stock wheel (rims+tires), then your speedo may be off (more so than the factory deviations). If this is important to you, you'd have to proportionally thin your tires as you increase rim size. If not, get 20's!
BIG-SHINY 20's!
two cents.
Old Nov 25, 2006 | 11:46 PM
painter1's Avatar
If its notBLACK its wack
I have just the wheel for you! The Enkei RPF1 is a very lightweight attractive wheel. It is the most common "track style" wheel you will find on this forum. The wheels are fairly priced as well.. some have even started powdrecoating them in black for a super stealth look!
Enjoy...
Attached Thumbnails Can someone of you guys make some suggustions-attachment.jpeg
Old Nov 26, 2006 | 08:07 AM
Wilson's Avatar
Peeping over the fence
The stock tires have an outside diameter of just over 26 inches new and just under 26 inches when worn out. Just keep your new tires as close to 26 inches as possible and you won't affect the speedometer accuracy.
Don't forget to post some pics after you get them installed.
Old Nov 28, 2006 | 10:42 PM
25.9.
Old Nov 28, 2006 | 11:07 PM
LionZoo's Avatar
road warrior
BIG-SHINY 20's!
two cents.
Definitely no 20 inchers. They make your unsprung weight hell and aren't unfunctional to boot.
The answer to this question depends on what width tire you want to run and what your tastes in looks are. I personally favor either the WedsSport SA70 or TC005; they aren't the lightest 18 inchers available, but won't break the bank, are fairly light, and relatively attractive. If you have an unlimited budget, I'd recommend either the Volk Racing CE28N (just about the lightest wheel out there) or the TE37. If you're racing, the Enkei RP-F1s really can't be beat.
Jesus Martinez
44
May 6, 2025 08:09 AM
M Pizle
Series II Exterior Appearance and Body Kits
Feb 2, 2016 04:47 AM
mariohardleft
Aug 28, 2015 09:26 PM
nnsoch1776
Jul 22, 2015 04:16 PM
westgman
Good Guy/Bad Guy
Jul 15, 2015 11:18 PM
