Turbo Oil Feed And Return Lines Question
Old Nov 23, 2006 | 01:54 PM
XCLUSIVSMITH's Avatar
BLACKICE
I Just Got My Turbo Kit And I Also Ordered The Greddy Oil Pan. My Question Is Where Do You Route The Oil Feed And Return Lines Do They Both Tap Into The Greddy Pan Or What? If Not Where Do They Tap Into?
Old Nov 23, 2006 | 03:12 PM
guitarjunkie28's Avatar
port hacker
you unscrew the oil pressure switch/sending unit, then screw the "t" in there. the return line has that fitting that replaces the factory drain bolt on the oil pan.
Old Nov 24, 2006 | 02:42 PM
mikeschaefer's Avatar
I wanna rock! Rock!
Yeah the greddy pan has two threaded holes side by side. Use the supplied fitting from the turbo kit and screw it into one of the holes. I forget which one but you'll immediately be able to tell because the way the turbo sits and the length of the return hose they give you.
Old Nov 24, 2006 | 04:10 PM
BLACKICE
Thanks For The Info. I Have Another Question Where Do I Run The Line For My Bov Where Do I Tap In??
Old Nov 25, 2006 | 08:40 PM
I wanna rock! Rock!
vacuum, and there are 3 sources
1) Just behind the throttle body where the VFAD was connected.
2) and 3) Passenger side of the lower intake manifold are two nipples that, in stock condition, are capped with rubber caps.
I used the TB one for the BOV and the other two for boost gauge and interceptor-x. Though I am considering using the TB one for the interceptor as recommended by mazsport.
Old Nov 26, 2006 | 09:04 AM
Terrance26's Avatar
8 all the way
which one are you using for the actuator on the turbo. I am using one nipple on the lower manifold for my boost gauge, the other for the actuator on the turbo, and I use the one by the throttle body for the emanage ultimate w/a T fitting and the blow off valve
Old Nov 26, 2006 | 09:05 AM
Terrance26's Avatar
8 all the way
The hardest part of hooking up the turbo was getting the oil line feed in to me, because it was such in a cramp area.
Old Nov 26, 2006 | 09:40 AM
I wanna rock! Rock!
Yep that was a pain.
It is highly suggested you tap a compression pipe with a 1/8" nipple for the wastegate actuator signal. I tapped the one bolted to the turbo but technically any of them would work. You just don't want to connect to anywhere after the throttle body. It will cause the turbo to overspeed. Read the greddy turbo kit definitive fixes thread.
Skyl3r
Dec 2, 2019 04:51 PM
UHATEIT
Mar 31, 2019 05:31 PM
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
Stubbs
Jul 28, 2015 09:23 PM
